Water problems! (1 Viewer)
paulel
49
35
Brittany
Hymer E650
New
I turned the water on thinking there was water in the tank but it was empty, so of course, no water came out of the tap! I then filled the tank and tried again. Water came from the cold side but slower than usual, nothing from the hot side. I did discover water running from an overflow pipe when I turned the tap on. I don't know if it has anything to do with it but the gas ran out at the same time. Anyone any ideas?
Jul 29, 2013
9,072
18,586
Salisbury
Hymer B678DL A class
Have you checked the boiler water dump valve as its automatic and may have turned on!
paulel
paulel
49
35
Brittany
Hymer E650
New
Wow that was quick! The people I bought it from put a peg on the valve, it's still there.
Vlad The Impaler
1,633
2,227
Rutland
Since 2012 but longer in my dreams
If it's a yellow pull up one remove the peg and flip it down flat ,then flip with water.
When draining down you pull it up to empty the boiler and allow air in to assist with draining the system.
Vlad
paulel
paulel
49
35
Brittany
Hymer E650
New
It's a black unit with a red plunger on top that moves up and down, the peg keeps it in the up position. I haven't had a problem with it up to now.
Vlad The Impaler
1,633
2,227
Rutland
Sorry can't help but someone else will I'm sure,make and model may help .
Vlad
Jan 29, 2014
1,317
975
Scunthorpe
Autotrail Apache
July 2013
Yes it will be the hot water dump valve . If open water will come out under tne van. I foget to close mine all the time, after drain down.
paulel
paulel
49
35
Brittany
Hymer E650
New
I thought it was that yesterday and tried lifting it up and down but it didn't make any difference
Sep 3, 2012
7,559
26,089
Cheshire
C Class Elddis 175
8+ years
The peg stops the valve from opening and dumping the water. Normally when the weather is cold the valve will open at around 8 deg C for a Hymer. The peg is used to stop the valve opening. It would seem you have another issue elsewhere with water dumping -maybe a split hose or a clamp has come loose-My hymer has jubilee clips all round at the joints that used to come loose at times. trace where the water is dumping from and work back to the taps-favourite in mine was under thesink
DanielFord
3,020
3,086
Well that would suggest the pump is running dry, are you airlocked? Many way to clear and airlock, simplest is to open a mixer when halfway between hot and cold, but cover the tap with your hand to prevent water coming out of the tap.
paulel
paulel
49
35
Brittany
Hymer E650
New
As far as I could tell late yesterday evening there is a t connection on the pipe coming from the tank with a pipe that goes through the floor and that's where the water is flowing out. I'll have to have a better look tomorrow.
paulel
paulel
49
35
Brittany
Hymer E650
New
I wondered about an airlock as I run the tap for a while with no water in the tank.
