water loss
Paul and Pippa
Dudley
Dethleffs Advantage
I'm a newbie
Hi all ,,again, my MH lost all the water last night. I think it was a safety drain valve in the Truma heater ..I have closed the valve and filled up the on board water tank ,and opened the taps but still no water is coming through the taps after 20 mins ,,can anyone advise please
opps spoke too soon ,,I have water lol
Some of those valves dump at low temperature it’s in the design. They can be a pain
It is.. It's the 3rd time it's happened grrrrrrr.
Did you close and lock the valve because if you do not then the pump will not be able to catch up that quickly. It is filling the heater at the same time the heater, is dumping it look underneath while it is filling to make sure, it might get some into the system but a long time and most of the tank outside.
Yes l did that thanks.. I lost water twice,, it happened before but never took 20 mins to prime the pump.. all sorted now.. thank you for your help..
