It looks like it twists a bit but then locksIs it twist to lock?
Thanks, turning the key doesn't seem to move the plastic caps at allThe locking part of those caps is rubbish. But anyway, try turning the key until the rotating tabs on the cap are in the open / unlock position before putting the cap back in place. Then lock using the key.
In theory, when you turn the key, the moving tabs rotate from unlock to lock and vice-versa. With mine it seems to make no difference. When mine is supposed to be locked, anyone can easily remove the cap without the key.
Edit - not all lockable caps are the same . Maybe the OP's is slightly different, although I can see the small clear plastic tabs in the 1st photo.
Landy Andy has said yours appears to have the locating neck collar missing.It is a common problem where it comes unglued & stays on the cap.looks like someone has thrown yours away. They can be superglued back in.If it is missing you need a complete new cap & neck assembly.Easy to fitAre you sure the two parts are supposed to be together?
I see lugs on the cap, but nothing on the neck.
Thanks to everyone who responded, I found a cap on Ebay but not the neck assembly .... yet!To remove you turn the key 90º anti clock wise Then push in & turn the cap the same way. To refit you align the lugs with the slots on the neck,push in & turn 90º clockwise. then turn the key 90º clockwise leaves the cap locked but rotatable.
As
Thank you so much, on order now!It’s a Zadi system
40mm Water Tank Filler With Cap & 2 Keys - White
Water Tank Filler Cap 40mm White 40mm water inlet with a lockable cap. The filler inlet and pipe neck diameter measure 40mm and the cap comeswww.aandlleisure.co.uk
This shows the normal locating parts
Back in 2019 I bought a brand new one still bagged at a car boot for 50p.It’s a Zadi system
It's the one I used when converting this van. Forum posts reflect the views of individual users and not MotorhomeFun.
