Water ingress in new(ish) motorhomes? (1 Viewer)
Apr 2, 2017
60
66
North Yorkshire
Rapido 854f
Since 2002
Evening all,
I had a look at a nearly new A class today with a view to possible purchase.
Registered April 2022 with 1400 miles on the clock. The van looked very clean and tidy as you would expect.
Paperwork from the hab check in April 2023 revealed that the dealer had identified water ingress on the two back corners of the roof and the rear near side floor of the garage. Dealer advised that all has been made good under warranty.
I had a very close look at the areas and all looks perfect, there is absolutely no evidence of any current issue.
Talking to the dealer he said that they see a surprising number of 1 year old vans (all manufacturers and models) with water leaks identified at their first hab check that have to be fixed under warranty.
Does this sound reasonable? If it is a fairly common issue and, once properly sorted, should be no cause for concern then I’ll continue looking at this van. Or should I run a mile?
I would appreciate your thoughts and experience.
Many thanks.
Feb 16, 2020
2,284
3,103
KT15.
Sunlight. T66. 2019.
Absolute beginners.
An independent verification all is now well would be a good starting position, but no reason why a professionally repaired shell should leak again. If purchased though, a good quality moisture meter should be one of your first purchases to catch early any reoccurrence.
Mike.
868
1,933
Nr Wigan, UK
Rapido A Class
Ask the said dealer for a longer warranty on the repair. I think you have or have had a Rapido A class. If it’s a Rapido you’re looking at 😉😉 what’s the quality like and how would you compare.
irnbru
13,514
31,142
Glasgow
Benimar 264
11 yrs
I personally don't see anything wrong with it if its been repaired to a high standard. I'd guess there are a lot of van owners out there that dont know their van is leaking, either cos they haven' t noticed it or its normally kept undercover. It wouldn't put me off, mine had water ingress too.
Derbyshire wanderer
1,297
2,396
Derbyshire
C class
15 years
My last van bought new was three weeks old and a good downfall of rain found a faulty window seal and stained the seat cushion. Warranty repaired eventually after a failed cushion clean so new cushion took nearly 3 months to get even though seal was sorted within a couple of weeks
5,962
31,720
East Anglia
Kontiki 669
Since 2010
I personally would walk away.
It was picked up as damp in April this year, and all three areas have already been repaired,that’s been sorted very quickly as we know dealers are always very busy at this time of year.
I would want clear evidence of what they have done.
Lenny HB
53,493
150,283
On the coast in West Sussex
Hymer B678 DL
Run away very fast, you don't know to what standard it's been repaired.
If it was leaking seams they probably just resealed them and dried them out, when a proper repair would involve stripping off the internal wall boards and checking for damage.
What van is it?
Swamp
Apr 2, 2017
60
66
North Yorkshire
Rapido 854f
Since 2002
Thanks everyone for your replies.
A few differing opinions but all valuable.
I shall give it some more thought 😁
Swamp
Apr 2, 2017
60
66
North Yorkshire
Rapido 854f
Since 2002
Mike.
Thanks Mike.
Do you have any recommendations of a damp meter model that would be suitable?
Nanniemate
6,137
43,102
Wales
IH
We have had good weather recently giving the van time to dry out damp may not show up again until we get some rain
too late then you've bought it and it could become a problem
1,803
15,244
South East but not London
Rimor Europeo 87
Five years plus three tugging
Evening all,
Many thanks.
"Talking to the dealer". Have to say that even if a motorhome dealer was my brother, I wouldn't believe a word he says. They are there to sell motorhomes, not to give a monkeys about you. First, I have heard about a surprising number of new motorhomes have leaks. Sounds like sales patter to me.
Notwithstanding that, the issue is mostly about current condition -v- price. If this bus is the exact model that you want, and is set at a price you consider fair, then proceed, but get a few grand taken off and a lengthier warranty on water ingress, as Fdhadi says. However, if you are making compromise's in your 'want list', on the basis that it is affordable, then I would say, keep looking.
Personally, it would have to be MUCH cheaper than book price, and definitely fixed, before I went for a van that had historical water issues.
Gellyneck
9,245
18,337
Scotland
More than toes wet now!
Thanks Mike.
We've got two of these (home and motorhome) Amazon product ASIN B003CSNV2Q
Got local guy to "test" against his professional kit and they came out very close to his readings.
Other will prefer pinless options though.
2,284
3,103
KT15.
Absolute beginners.
Thanks Mike.
There are two types available, invasive = with small pointed prongs that actually pierce the surface material to obtain a reading, or the non invasive type, these are able to obtain a reliable reading, but no marks left to evidence they have been used.
There will advocates for both types, and detractors for both.
Best have a look at the familiar market places, at both types and make you're best educated guess at a budget you're happy to pay, which will range from a £tenner, up to ?.
For my part, I have a small invasive Ebay one £10.00, that I carry in the van, and monitor readings using the same pin points that have been made when the annual water ingress check has been done.
I had some elevated readings on a garage door, which being a stand alone isolated panel didn't concern me unduly, especially as I was able to pin point the fault to a joint in the door make up panel, which was easily rectified with some "helicopter wing edge tape" over the joint. I have monitored the levels fall away to well below 10% from the high 20%s.
Mike.
