Waste Water Drain Valve
kpink
Van conversion
Hi, just taken delivery of a new (2021) Twin Supreme 640 SLB. We cannot find the tap that empties the waste water tank - been right under the van, but unless we are going mad, its not there! Have Adria introduced some other way to do it? We hired one last year & it was all blindingly obvious!
:hiya2: w2f
Does the manual not have that info?
Usually a tap just under the side skirt. Can be a lever or turn knob. Our Burstner uses a spanner kept in the water locker
The outlet will be something like a 32 or 40mm waste outlet like under your sink at home.
They are usually easily accessible.
Good luck
Open the toilet external flap. Red lever, put in hole and turn. Check instruction book for photo.
Thank you all so much for your replies- Andy MacD - you win the prize!! I have to say, the Adria manual is awful - it obviously hasn't been updated so we have been looking in completely the wrong place, under the van for the "tap". Thanks again!
I found that key point when I looked at the same van last weekend when we ordered ours. I couldn’t see how you fill the fresh water tank full & where the overspill came out of the tank. On my Bessacarr it was an underslung tank so it flowed easily out of the ventilation holes and onto the ground safely. Never had an onboard tank before so no idea how it safely goes outside when filling
