DaveFromBarrow
As I continue to "debug" my MH (2008 Apache 634) I want to solve this issue.
Waste tank empty - all plugs drain well.
Waste tank has two or three buckets full of water - plugs drain slowly. Opening the waste valve = plugs drain down normally.
My thinking is the waste pipes are too long and sit in the bottom of the waste tank and once there's a small pressure of water in the tank there's not enough pressure in the pipes to overcome this resulting in poor drainage.
My solution, unless advised otherwise, is to shorten the waste pipes so they only go into the waste tank by 50-75mm.
Anyone else had this issue?
d
d
