Warning - Swift escape over-cab window (1 Viewer)
Dare_Devil_Dennis
296
199
Derby
For owners of 2017 Swift escape based motorhomes PLEASE READ...
I bought a dealer special Escape based 684 which was delivered in March. I was impressed with the push to operate window stays on the main windows that you do not have to tighten a pinch knob to secure the window open. They fall back to a preset open setting depending on how far you push it open. gravity holds it in the open position against a mechanism inside the stay. you reset it to close the window by pushing the window out as far as it will travel, then it returns to the closed position. Takes longer to explain than to understand it first time and to use it. A nice design. They are great for "top hung" windows.
However, Swift have used the same design of stay on the roof mounted panorama window over the cab, which is a massive mistake which resulted in the window blowing out, breaking along the bottom across the hinge area and ending up on the ground in front of the m/h. Check out the pictures. Why did it happen?
The window was open on the first (smallest opening) setting. The Thule awning was fully deployed as was the Heki roof light at the rear of the roof over the beds. It was a little breezy, but nothing "exciting". Now, please recall that the stays are free to move against a push of a hand and have no means of locking in position. A gust of wind passed over the roof and picked up the window. The window is "bottom hung", (the hinge is at the bottom) and the window sits, normally at 45 deg on the sloping cab roof. Once the window started moving, it accelerated to the almost vertical where the wind force was at a maximum- like a sail on a boat, the inertia of the window and the forces exerted broke the stays and the window continued its trajectory until it snapped at the hinge and landed on the ground in pieces. The awning and the Heki windows were not affected by the gust. The Heki roof light has a catch it locks in to when partially open so is restrained.
A call to my dealer resulted in a quote for over £450 + fitting + VAT for a new window and an assurance that this could not be a warranty issue. A very disappointing response.
After writing a full report and forwarding it to the dealer Customer Service Manager it was submitted to Swift for a warranty claim - rejected on the grounds that "you should not be driving with the windows unsecured"!!! An amazing response as the report I submitted explained that the awing was deployed and I was sitting outside the m/h at the time. After this was pointed out, they conceded that they would accept the claim and the window has been replaced. It took from mid June to early August to get the new window fitted.
The replacement window has the same stays! No way to secure the window when open. It will happen again without a doubt. The dealer assured me they had never heard of this before, but when I spoke with the technician who replaced the window, I asked him if he had seen this before he said to me "oh yes, we had one in a couple of weeks ago".
As far as I can see, only Swift use these stays on a bottom hung window like this. all other manufcturers have the clamp knob type. At one point I was ready to involve Trading standards as the window is not fit for purpose, but just in time, Swift stepped up to the mark.
If you have one of these set ups, PLEASE be careful how you use it. Thank goodness for Gorilla tape and super glue. took me best part of an hour to patch it up and refit it so I could get home. (yes, it was about to rain which started just as I finished!
This matter needs an open discussion with Swift and their dealers, but I fear that will not happen.
32,686
66,697
Have you jointed the Swift forum? Might be worth raising it on there for others to be aware.
32,686
66,697
Just a thought, could you put a hook/loop on the edge of the frame so that you can put a strap around the centre securing handle on the window? Then when you open it in future it can't pull any further open - not ideal I know but at least you won't be faced with this again.
Dare_Devil_Dennis
Dare_Devil_Dennis
296
199
Derby
Joined the forum last night. responded to a post about paint sealants. Might be being a bit thick, but I can't see a button anywhere to post a new thread! eventually lost the will to live and went to bed.
Dare_Devil_Dennis
Dare_Devil_Dennis
296
199
Derby
I was thinking of changing the stays for the more "normal" design. need to do some research on ones that will fit or can be adapted. I'm not waiting for swift to do a recall. My Bro-inlaw. took delivery of his new Swift M/H last week so despite them being aware of this issue since June, they are still delivering with these unsuitable stays.
Puddleduck
12,387
44,010
Scottish Borders
Without at present
On and off for many years.
That is an awful design for a roof window. Our MH has that type of window along the van sides (I think many do) but three different designs of roof lights - none of which are the push-stay push-close type.
Dare_Devil_Dennis
Dare_Devil_Dennis
296
199
Derby
BTW, there is no centre securing handle, only on the ends. A temp fix would be a small ratchet strap around the two end handles and around a broom handle across the opening. Not pretty, but simple. Probably best just to not use it for now. for ventilation, there is always the first notch on the locking handles.
Dare_Devil_Dennis
Dare_Devil_Dennis
296
199
Derby
What occurred to me at the time is that if anyone was walking past at the time it could have caused serious injury. Did swift acknowledge this? Not a chance.
AXO66
762
4,715
Pembrokeshire
Chasson 510
Our CHAUSSON 510 has the same design, so good ( or not) to know about.for this. Suspect all current Chaussons have the same design.
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
We had these in our previous (non Swift) MH on the top hung side windows, and eventually they wear out and fail to engage in the open position. Our kitchen window ended up being propped open with a piece of dowel, but that was after about 9 years of use.
Having them on the top sky light is utter madness, not least because you have to push the sky light fully open in order to close it, and who'd do that in a strong wind? Surely you have a case with Trading Standards for the sky light being unfit for purpose? Failing that, maybe look at the piston-type stays that are used in car boots?
Our current MH is a Swift-built 2017 Bessacarr 484. By way of comparison the sky light is secured along its back edge by solid sliding metal struts using a crank up system with a crank handle in the ceiling. Absolutely no give if a gust comes from behind.
Clearly Swift have the capability to fit their sky lights safely, but are choosing not to in some models.
WynandJean
6,670
3,303
West Midlands
Bailey Autograph 682
Not thick. I was finding it less than obvious. You need to click on the Forums tab above and enter the specific forum you are choosing to post on. There you will find a button to start a new post. There is no such facility on the 'recents' overview page.
Wyn
32,686
66,697
Its a while since I've been on there but I think you have to have respond to other threads a certain number of times before you can start one.
Dare_Devil_Dennis
Dare_Devil_Dennis
296
199
Derby
Thanks for the tips on the swift forum, I'll try it later.
I have worked on a solution today. I found a dealer who was selling a pair of what look like compatible 150mm tube type stays with a clamp and was about to order them £19.95/pair. when I saw he wanted £9.99 for postage, I balked. (not logical, it just felt like an overcharge).
So, I took one stay off the window and took it into my workshop. I thought about drilling a series of small holes to put a pin (a removable "R" clip) through when the window was open on one of it's two stops to lock it all in place. I clamped the stay together with a small workshop clamp so it would not move as I was drilling. It occurred to me that as the stay was now locked together and that was what I was trying to achieve, there must be a way to do this clamping thing in place without modifying the stay. Here is my prototype.
The hose clip is a special, a sophisticated sort of "jubilee" clip operated by hand, not with a screwdriver. Made by Uvex (size22). I think a 22mm thumbscrew type jubilee clip would work as well. Between the inside of the clip and the aluminium stay is a short length of spiral cable wrapping to act as a sliding surface to protect the ali from scratching. It's made from some tough plastic like polypropylene and just slides beautifully without being squished by the Uvex clip.
With the clips slackened slightly, the window works as it should. when it is in one of the two preset positions, and the thumbscrews are tightened, the window is locked in place. doesn't look too shabby either (IMHO).
138go
3,276
14,613
Carthago 138
Since 2001
You have to be careful on the SWIFT Forum they don't like people complaining .. :rolleyes: ..
If you complain to much you just get .. BANNED
What a rubbish design. Wonder which bright spark thought of putting a side window on the roof. Are these windows designed for that. If you look at a normal roof window it has a proper seal round it and is shaped on the outside to keep the rain out, It also has a proper handles etc to lock it in place. All that window is relying on is a small rubber seal round the edge that touches the perspex and you cannot even lock it in place when its up.
Mbg
Swift escape
This has just happened to us on Monday. 2017 escape 685 same position as yours and gust of wind and window landed on road in front of our pitch. Cant believe it just missed a child cycling past. Our warranty was up last week but have emailed swift. This is actually a serious issue. I am going to contact trading standards if nothing is done as this should be recall this could seriously injure someone.
Mar 3, 2013
1,492
6,194
Poole
They are pretty rubbish even on side windows. I have one in my bathroom and kitchen. Both are a pain in the backside to get to stay open without a lot of fiddling and pushing on the arms. Why on earth they would fit one on the roof is behind me. One gust and off it went.
Cheshirecat57
3,482
5,590
Mid Cheshire
10 years on and off
We had nothing but grief with our Escape sunroof in the 9 months we owned
One stay locked at a different height to the other, then it jammed
The Elddis we bought last week has a windey-handle opening ststem
Was one of the little things weput a small “tick” against in the buying process
Good luck with the fix
PeteH
6,853
9,032
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
Ditto, Same type fitted to Rapido`s BTW. Fortunately ONLY as side windows but setting a window opening is a hit and miss affair.
Oct 12, 2009
10,708
23,729
A Class N+B Arto 69GL
View attachment 178790 View attachment 178791
What surprises me is that you seem to think this in 2017 was a new design.
Our N&B Arto 2003 has these.
Geoff
Jul 29, 2013
9,074
18,614
Salisbury
Hymer B678DL A class
We have them on our side windows in our 2018 Hymer and I have to say I’m not impressed with them in fact I once pitched close to a tree and opened the kitchen window one click when we went to close it was unable to open far enough to make it close.
Lesson learned.🙄
32,686
66,697
Lesson learned.🙄
We did that a few years ago ... hubby was cooking and rather than open the sliding door he pushed the window open ... all well and good except when he needed to close it he couldn't as there was a ruddy hedge preventing it being pushed out far enough ... we ended up having to carefully move the van to get enough space! :giggle:
Jul 29, 2013
9,074
18,614
Salisbury
Yes we had to do the same😊
Oct 12, 2009
10,708
23,729
Push hedge with a broom? - ours only need about 1" movement to release.
32,686
66,697
Good idea except it was one of those prickly very 'stiff' type hedges so no option but to move.
Feb 2, 2009
273
166
North West
Concorde
Quite a while.....though not long enough
Hi Nicholsong,
I've sent you a PM, but unsure if I have the correct person as I have deleted my old PM`s.
Please ignore if it isn't yourself.
ambulancekidd
Sep 23, 2014
10,375
28,401
Ayrshire Scotland
Swift Kon-Tiki 640
I'm utterly baffled by this fascination for "flooding light into your motorhome".
First things first, I hate feeling like I'm sitting in a floodlit goldfish bowl & the blinds are crap so you cannot even get darkness to sleep in, secondly & more importantly is the tendency for these goggle boxes to leak, just read the stories on here of major repairs required when a Heki roof leaks.
Seems to me that it'd be better for motorhome manufacturers to allow the choice before chopping huge plastic holes in a motorhome (or caravan) roof?
Oct 12, 2009
10,708
23,729
We are not fascinated with flooding light in, but we appreciate our large windows for seeing the view outside, including our v. large panorama w/screen, which we appreciate both when mobile to see mt. tops and when static.
We have good blinds for closing, including a metal pull-down one for the w/screen, so we can have light or almost complete dark.
Geoff
