Well my Victron MPPT Solar Charger is!.... seriously. Anyone got it horizontal on a ply surface?
Didn't say you couldn't did I? I put that there for the benefit of the op, I don't care how yours is mounted.As I said, mine works fine and does not over heat, you mount your as per the guidance if it makes you happy, and I'll mount mine how I want as it has been for the past 3 years.![]()
The OP doesn't refer to the type of charger they are asking about, mains, solar, B2B ?Didn't say you couldn't did I? I put that there for the benefit of the op, I don't care how yours is mounted.
So that is implying St. Vanbitz are fitting Victron Solar MPPT Chargers horizontally is wrong????And your point is? They are all the same.
B2B:
Smart Solar:
As I said, I posted for the benefit of the op. How you mount yours is of no concern to me whatsoever, do it how you want![]()
And where did I say that????So that is implying St. Vanbitz are fitting Victron Solar MPPT Chargers horizontally is wrong????
If the have mounted it horizontal it is wrong a professional should know better.So that is implying St. Vanbitz are fitting Victron Solar MPPT Chargers horizontally is wrong????
If mounting it yourself you are in a position to monitor it so not so much of a problem.
Wow! Rapido have mounted all the other Nordelettronica chargers horizontally as well!If the have mounted it horizontal it is wrong a professional should know better.
You are being picky tonight.We need to define horizontal here, side on on a vertical surface which is the unit horizontal and this will allow air flow, flat down on a horizontal surface will aid heat building up.
Doesn't mean anything unless you tell us what Nordekettronica say about mounting.Wow! Rapido have mounted all the other Nordelettronica chargers horizontally as well!
Well yes, all my charging modules lie flat down in the same plane as the floor! Never considered heat ventilation but the boat chargers were indeed mounted on a vertical bulkhead which would naturally dissipate heat!We need to define horizontal here, side on on a vertical surface which is the unit horizontal and this will allow air flow, flat down on a horizontal surface will aid heat building up.
No idea on the Nord stuff but are Vanbitz really fitting Victron MPPT Chargers contrary to specification and in reality is it really a big deal or a bit of overthinking?Doesn't mean anything unless you tell us what Nordekettronica say about mounting.
I think we know we are talking about mounting horizontal on a vertical surface which is probably OK if not running at its max output. But if running flat out in a hot inviroment it should be vertical on a vertical surface.
I noticed there is a Multiplus 3000 mounted flat in its back on the floor in a Hymer that is for sale on Simon's site now that is a real no, no.
Victron solar chargers will start to throttle the output if they start to get too hot. This limits the heat generated but of course you won't get the full output either. You may not notice this happening so would not be aware it was going on.Well yes, all my charging modules lie flat down in the same plane as the floor! Never considered heat ventilation but the boat chargers were indeed mounted on a vertical bulkhead which would naturally dissipate heat!
So just wondering how critical it is in reality for a campervan, not had any issues so far so will not be losing any sleep over it.
100 watts is only a few amps and not going to generate much heat you might think differently if you had 500 or 600 watts.I have a little 100w solar panel and heat will rise from the MPPT quite naturally no matter what plane it is fitted in. If I had the solar array that some of the full timers have I might be concerned! I think this post has been over geeked!
Quite, that's what I thought, I'm a little fish in the pond!100 watts is only a few amps and not going to generate much heat you might think differently if you had 500 or 600 watts.
Yes I have it fitted like that but with 2x small 12v computer fans blowing air over the heat sink fins on the back. Fans come on automatic when the Victron is in use ( I have my charger independently switched, not through the van ignition). No issues this past year..... seriously. Anyone got it horizontal on a ply surface?
That is very bad practice a Multiplus should always be mounted vertically. I wouldn't trust any so called professional that makes basic errors like that.They fitted our Multiplus 2 3000W Inverter/Charged “horizontally” on a vertical plane (sideways) under the lounge seat
