marchie
- Mar 9, 2021
- 2,279
- 6,140
- Burstner
Yesterday's Brake Fluid Thread prompted me to check Brunhilde's Service paperwork, and I can find no mention of the Brake Fluid ever having been changed from first registration in 2016. She had covered only 8767 miles when we bought her, and I discovered in those baking days in mid July that the aircon had never been regassed, so the previous owner not having had the Brake Fluid changed doesn't surprise me! Brunhilde booked in for Tuesday next week for this job.
Whilst rummaging round in Brunhilde for the service paperwork, I checked the Control Panel for the vehicle and leisure battery states. Leisure battery was sitting at 13.8v and grazing from the solar panel quite happily. The vehicle battery [Brunhilde hasn't been moved for 20 days because of the fuel shortage] was not so good; the Control Panel was showing a tad over 11.6v, so it was a 'fingers crossed' job when I started her up today. She started instantly, with no hint of any struggle for electrical power. After a 20 miles local trip, including about 6 miles on dual carriageway at GPS measured 55mph, the Control Panel reported the Vehicle Battery at a tad over 12.0v.
The garage that will be doing the Brake Fluid change did a Battery Check, including a Drop Test, and reported that the Battery was sound. They waited around 25 minutes after I arrived before checking the Vehicle Battery to settle and said that the Readings were 14.22v when the engine was running. They said that they regard the Battery as sound and would not recommend replacing it. They suggested that the almost 3 weeks break in using Brunhilde, allied to the Autumnal temperatures was the most likely cause, and suggested more frequent use of the vehicle! [and 'keep an eye on it' ...]
My concern is that the Vehicle Battery is nearly 5.5 years old and, with Brunhilde having covered only 1750 miles each year, the recent voltage drop might be an early warning of failure. I don't want to risk the Battery expiring [especially when we are in Spain!] and it causing an ECU fault, but the garage said it seems silly to replace a healthy battery. Any thoughts? They did suggest that the gradual current drain over 3 weeks [Pioneer stereo that Lenny HB has referred to previously?] might be the culprit. I have left Brunhilde for about 3 weeks in late July/early August, and the vehicle Battery was reporting about 12.25v on the Control Panel, in much warmer temperatures.
While I was at the garage, I booked Tig in for an oil and inspection service, so this month will be another heavy load for the Cretin Card! And that's before we decide on buying Winter Tyres for Spain at around £480 [but the garage will refit the current tyres for Spring/Summer, so, in theory, I should get a boost to the tyre life by running 2 sets on an alternating basis.
Any advice or thoughts will be welcomed as usual!
Steve
Steve
