VB-Semiair - price guide? (1 Viewer)
The Returnee
149
113
Togo
In 1983 I drove from England to Lomé
Hi Folks,
Do any of you have a guide price for the kit and install costs of VB-Semiair - rear only? Is so please share. :)
I have a Merc-based Charisma 2006.
Thanks.
Neckender
3,221
5,923
Neckend or North Wales.
VW T6.1Kombi day Van
Since 2004
Here is a DIY kit on eBay for pre 2006 there are others post 2006,
If your a good DIYer very easy to fit yourself.
John.
The Returnee
The Returnee
149
113
Togo
@Neckender
Thank for the thought. yes I could fit it by the looks of it - and I will explore further on ebay. That particular kit seems to be for a single back wheel. I've got two. I don't know what the diference would be...
Aug 4, 2018
91
33
Derbyshire
Hymer BMCi600
Since 2018
I recently fitted a kit on my Merc/Hymer, bought it from Airride, made by Dunlop.
Quick and easy fit
Jul 29, 2013
9,176
20,370
Salisbury
Hymer B678DL A class
since 2011
From memory we had VB fitted to our Exsis on an Alko chassis and it was around £1600 complete with internal gauges and valve switches and fitted compressor.
We also had EP jacking system at same time.:xThumb:
That was three years ago.
ABZSteve
Banned
Jan 8, 2014
1,524
1,658
Aberdeen
2018, Apache 634 150 Auto
Since 2015
Hi Folks,
Thanks.
I was £770 fitted in March this year. Additional £300 if gauges and pump required.
The Returnee
The Returnee
149
113
Togo
@Speve; @ABZSteve
Thanks both, but look at the differences!
This includes the kit that replaces the rear leaf springs?
ABZSteve
Banned
Jan 8, 2014
1,524
1,658
Aberdeen
Since 2015
@Speve; @ABZSteve
No replacement of leaf springs required :xThumb: Also, not an Alko chassis.
Semi air suspension
VB-SemiAir enables the suspension to be adjusted (manually) within specific limits.
On a vehicle with leaf springs, an air spring is fitted between the chassis and the rear axle. This air spring supports the existing leaf spring.
VB-SemiAir is supplied as a two-chamber system, which means that the air springs are not connected to each other. The use of a dual chamber system allows left and right to be adjusted separately, enabling the vehicle to be levelled, even when it is loaded unevenly.
Benefits of VB-SemiAir:
  • Higher ride height and increased spring travel
  • Improved stability
  • Reduced off-centre level
  • Variable spring force
  • Good value for money
  • 'Plug-and-play' system allows for quick installation
  • The body, equipment and load remain protected against damage
  • Heavy loads are no longer noticeable from the outside
  • Less strain on the shock absorbers
Apr 22, 2018
7,242
13,278
Herts.
Adria Coral lowline
The prices will vary a lot. I’ve been looking into this myself, and there are kits, and there are kits. Especially if you are going for a system with a built in compressor and gauges. Some are really basic looking, and other are a very nice posh set of gauges, and switches.
I started off just wanting basic kit, no pump, or gauges, but now am thinking more towards full system with pump, gauges, and being able to alter from the cab.
Andy.
Jul 29, 2013
9,176
20,370
Salisbury
since 2011
On the van we have now we have Golschmitt full air and it’s great it automatically adjusts as driving but has lots of different settings and self levels when on site.:xThumb::xThumb:
Apr 22, 2018
7,242
13,278
Herts.
Adria Coral lowline
I’m not at that level, excuse the the pun, I’m more thinking, compressor and rear air assist.
But I am envious of your system. Enjoy
Nov 17, 2012
1,962
2,649
WEST SUSSEX
HYMER B SL 674
SINCE 2005
we used Rosana in Bolney, West Sussex, for our last vehicle, Hymer B544. Very professional and cost £1100 I sort of recall. Included the internal gauges pump etc. It also made a big difference to the ride.
Just had an estimate for our B SL 674 and because it was an alco frame it was just over £2k. i would not want to fit it but good for them that have.
Jul 29, 2013
9,176
20,370
Salisbury
since 2011
We had the VB for rear air assist on our Exsis to keep the back more stable when towing the car trailer it worked a treat good luck with whatever you choose and Happy Christmas to you and yours :xgrin::xgrin::xgrin:
Feb 24, 2013
13,467
102,825
Bolsover, Derbyshire
Hymer S800
not long enough
I quickly learnt that all significant upgrades cost about £5K :)(y)
but that would at least give you full air, not quite sure what semi is
edit
hang on, no comments please :whistle:
these days semi is good (y)
