haganap
- Dec 5, 2007
- 13,064
- 28,638
- Niesman+Bischoff 79e
- I'm an oldbie MH number 10
Ok, where to start, here's a story, please read on. If it's not sorted soon, look for me at the nearest bridge, my head is offically cod and battered.
I purchased a tow bar and electrics from a friend of mine dedicated to fit my van. It was working when it came off so I had no reason to doubt its working now.
I installed it on the van which consists of doing the following, Unplugging 1 cable, leaving 2 scotch type connections, these are then pluged in to the new loom made for the swift van. Then locating a plug near to where the towball is fitted un plugging it and plugging the new one in. Then there is two plugs in to the westfalia box and a relay.
this = job done. other than connecting the earth strap.
So I done all this and plugged my tail board in, and no lights of any sort. All the lights on the motorhome work as they should do.
It was then suggested that maybe there was a fuse gone in the van? I therefore checked every fuse loacted this side or manchester and checked it, still no working. Then, I spoke to the seller of the towbar whom insisted it was working but happened to have a complete loom and westfalia box as a spare so I could check a few things out. all that plugged in and same problem.
So moving on, I had a good think about it and plugged the old loom back in so i could return the new one. I then disconnected the earth on the chasis that comes with the towing electrics and checked at the socket with my multi meter. I placed a prong in the earth of the plug socket, and probed the other pins, all of them showed live when I turned the van electrics on with hazzard lights. I then completed the same process at the tailboard lights and again showed power at the bulbs. However, when I then touched the earth cable to the chassis, the power seemed to dissapear ? giving no reading at teh towing socket, release the earth and power comes again?
I plugged the car in to be sure it was no the tail board and when plugged in, one indicator flashes on the car but nothing else, and then it's debateable as to what happens in the car electrics next.
My thoughts are that there must be an earth fault? is it because I have been unable to secure an appropriate earth with the earth strap? Even though I can rub it hard on the chasis to no evail, and why does the power die when I touch the earth on to the chasis?
Any ideas would be helpful, even simple ones, to ensure that I have considered simpe things
