How difficult is it to up plate Autotrail FB.
Plus what weight can you up plate TIA
You’ll need to contact SV Tech and know the following before you speak to them.How difficult is it to up plate Autotrail FB.
As others have said in the past, only use JR if you know exactly what you want and check everything he sends carefully. I have my upgrade now but have a certificate/weight plate with 2250kg on the rear axle, despite all received wisdom on this forum that the maximum allowed on the chassis is 2240kg and the fact that tyres for 15" are only readily available in 112 load rating. Somebody else found a mistake in the VIN number on their documentation.a much cheaper route to getting the required engineers figures is use John Ruffles of JR Consulting
He's a lovely chap.
I suspect many have used his services without realising they have been given the wrong information and are very happy with their high weight ratings. It’s not right to say his problems were only when he first started doing motorhomes. There’s probably less negative reviews on here because people are being sensible enough to not use his services.Many people have used John Ruffles without a problem
He is fine if you have the technical knowledge and know exactly what can be done to your vehicle to obtain the desired result but if you need advice it's SV Tech.a much cheaper route to getting the required engineers figures is use John Ruffles of JR Consulting
... and some people are happy with his services but those who aren't are the ones who continually lambast him. We don't know in some cases exactly what info and the accuracy of it that has been supplied by the customer to get their uprading so without that info you can't 'blame' JR. SVTech have been doing this for years so have a 'databank' of all the possible scenarios so will be able to advise more quickly on 'unusual' situations or for those customers who don't know exactly what they want doing, but if they want to go to them for a simple upgrade which is, most of the time, a paper exercise then do so, but I'd rather save over 50% of the cost by using JR.I suspect many have used his services without realising they have been given the wrong information and are very happy with their high weight ratings. It’s not right to say his problems were only when he first started doing motorhomes.
That's one of the best 'kop-outs I've ever read!There’s probably less negative reviews on here because people are being sensible enough to not use his services.
Thank you everybody we really appreciate all the answers. John is gathering all the info and will definitely be contacting the people you have mentioned while we are in the UK. We will be over for May, June, and July. So that should give us time to investigate.
I have to say Mindy that I have used Sv Tech successfully and tried John who replied once to my initial request then on asking him if tyres needed to be updated he didn’t bother to reply so you can guess who gets the businessbut I'd rather save over 50% of the cost by using JR.
Sorry Minxy bleeding spell checker againIt's MINXY ...
... or do you want to be my Mork?![]()
I would tend to trust SV TechHmm ... everyone seems to say SV Tech give best advice BUT they have only updated my Campscout to 3850kg whereas John Ruffles uprates same van to 4500kg. I’ve double checked with them but they are insistent. Kind of feel cheated. Maybe check with both first.
Why? Unless Grianan's van was specifically built on the maxi light chassis there's no reason why it can't be up-plated to the max of 4500kg.I would tend to trust SV Tech![]()
@Grianan - do your VIN plates show the same as mine?
The 'good' news is that SVTech apparently do a 'free' further uprate so you should be able to get them to do it FOC assuming they will accept what they are being told!Will check in the morning ...
JR and those on the forum who have had their uprated to higher rates are correct, the maxi heavy chassis can go up to 4500kg without modification. I can only assume that SVTech believe it is on the light maxi chassis and that's why they've said it's only able to go up to 3850kg ... it could simply be a mistake made by whoever looked up the info for your vehicle and picked the wrong figures, assuming of course that yours IS on the heavy chassis - without knowing exactly what your weight plate says though it's speculation.So how do you (does one) determine who is right? They obviously think they are and JR wouldn’t update to a higher weight if he didn’t think it was right.
