I don't think most motorhomes are Faraday cages unless they are aluminium construction.We always unhook during lightning storms, you never know, that's our only contact with the ground so we're not a Faraday cage then.
Ask @Taran_Las he is the Lightning expert on here.Sitting in our van at Pompeii with the mother of a storm going on . Should we unhook?
Worse being here as youre not quite sure
Where the rumbling is coming from haha
One of the Carthago selling points is that they are a Faraday cage with the double aluminium body.A STEEL car will be a Faraday cage, but I doubt that a plastic van will be.....
Mitch..
PS.. But, we live in hope..
I don't think you need to worry about the jacks as it will earth with or without them.One of the Carthago selling points is that they are a Faraday cage with the double aluminium body.
If we have the jacks down it will give the lightning a quick route to earth so should we retract them in a storm do you think?
Richard.
if you think that scary ,try being in a yacht with a 40ft high lightning conductor sticking in the air
Or kayaking a couple of miles offshore with a carbon paddle and being caught out by an unforcast thunderstorm
Been there 40 miles offshore in a kayak with Carbon paddle shafts as you say, the Lightning was so close you could smell/taste the ozone it produced, pretty scary afterwards.
Martin
I think the benefit of having jacks down grounding the van is that it stops it sitting at a different potential to ground which if just sat on rubber tyres means you would become the conductor when you step out, jumping should be OK.One of the Carthago selling points is that they are a Faraday cage with the double aluminium body.
Richard.
Sounds hair raising!I think the benefit of having jacks down grounding the van is that it stops it sitting at a different potential to ground which if just sat on rubber tyres means you would become the conductor when you step out, jumping should be OK.
I think.
Martin
Faraday cages are alright but not fibre glass ones, bit like a strike whilst driving a Reliant.We always unhook during lightning storms, you never know, that's our only contact with the ground so we're not a Faraday cage then.
I can see it now, a detailed preserved plaster cast of a motorhome with a hook-up still in place..Sitting in our van at Pompeii with the mother of a storm going on . Should we unhook?
