Sink was blocked again with toothpaste and spit, so filled a 50cl water bottle with water, inverted over the plug hole, crushed the bottle to force water thru....glug, glug, water drain away nicely again...simples
Do you open the blade first? Not sure that’s a tip for me, I have enough trouble bending down to sink level, no chance of getting close to toilet bowl.You could avoid it altogether if you spit into the toilet bowl, that's what we do, no nasty mess in the sink then.
I can also confirm that for narrow gaps above the outlet hole (where a bottle would not go) such as ours with a tip up sink, a bicycle pump works wellSink was blocked again with toothpaste and spit, so filled a 50cl water bottle with water, inverted over the plug hole, crushed the bottle to force water thru....glug, glug, water drain away nicely again...simples
Probably reinforced with hair etc!!!!. I usually just 2/3 fill with water and flex the palm of my hand over it like a sink plunger. I then run some hot water through to try and clear itSink was blocked again with toothpaste and spit, so filled a 50cl water bottle with water, inverted over the plug hole, crushed the bottle to force water thru....glug, glug, water drain away nicely again...simples
Annie, you obviously wern't the Shooter on the school netball team then?Do you open the blade first? Not sure that’s a tip for me, I have enough trouble bending down to sink level, no chance of getting close to toilet bowl.
But what would happen if yer teeth flew out ?You could avoid it altogether if you spit into the toilet bowl, that's what we do, no nasty mess in the sink then.
Well, you would be wrong, of course I was, having the closest reach to the basket.Annie, you obviously wern't the Shooter on the school netball team then?
How narrow is the waste pipe ?Sink was blocked again with toothpaste and spit, so filled a 50cl water bottle with water, inverted over the plug hole, crushed the bottle to force water thru....glug, glug, water drain away nicely again...simples
Ours does. It is narrow bore, maybe as much as 10 mm ! With an outlet cover that is quartered and only 2 quarters fit directly over the pipe underneath. A toothpick just about goes in.How narrow is the waste pipe ?
Shouldn't block with spit and toothpaste.
A small plunger may be an alternative to crushing a plastic bottle, many sinks are a bit fragile
Our pipework is rigid but the plughole is one of those really small ones, the hole is less than an inch and clogs up really easily, hence spitting into the loo as I then don't have to clean the plughole every time.How narrow is the waste pipe ?
Phil
Don't have that worry they are all mine
So are mine though the denture ones I have consistently had to spend my hard earned to a dentist for !Don't have that worry they are all mine
OK I heard you the first time.Please be aware that a lot of vans have push fit pipes. Too much pressure and all that nasty blockage will empty in your cupboard below the sink. Likewise a plunger could be disaterous to a thin plastic sink
I was going to suggest the very same, works for van and home plug holesTo clear blocked sink:-
Vinegar
Bicarbonate of soda
Hot water
Method:-
Couple teaspoons bicarb into sink plug hole, gently push as much as you can down with fingers or teaspoon.Mix vinegar with hot water about 1/3 vinegar to about 1/2pint h.water. Pour slowly down plug hole and put the sink plug on place. Leave for 10 minutes and then pour more hot water down.
My continental build has decent size pipework so no blockages everI can also confirm that for narrow gaps above the outlet hole (where a bottle would not go) such as ours with a tip up sink, a bicycle pump works well
+1. Usually works a treat, but if the sink or basin has an overflow then hold a wet flannel or cloth over it as you "pump"..Probably reinforced with hair etc!!!!. I usually just 2/3 fill with water and flex the palm of my hand over it like a sink plunger. I then run some hot water through to try and clear it
