Tyre sealant anti puncture
Winnersh
Panel van
Since 2014
Hi,
I am at Truckfrest and someone is selling
Oko tyre sealant that they pump into your tyres it prevent future punctures and your tyre deflating
At a cost of £30.00 per tyre.
Had anyone got experience of this ?comments would be welcome
I've run it in motorbikes in the past. I have an Oko equivalent in a trailer now that had a pinhole leak in the steel rim. £30 a pop seems a bit expensive to me.
If you do get it fitted, warn the tyre fitter next time you get a tyre changed, they don't appreciate looking like an extra from a bukkake movie when they take the valve core out !
Thank you ,what’s your equivalent?
i use it often . buy it in farmers merchants about 8 quid a litre . works great.
ideal for small leaks etc .
when going to the desert in africa its a must. you get loads punctures there while driving in the sand .
I have something similar in mine. Not as much as that though. Shop around a bit.
And of course it does nothing for sidewalk damage. If it seals a puncture, I assume you remove the foreign bony and let it fill the hole. How big a hole does it seal and are there any speed limitations afterwards. At £30 a pop someone is making a huge profit, to pay for their exhibition stand
Having said that I have Slime in my bike tyres, a bottle for both wheels cost £5, that prevent the once a week puncture I got from going down a lane near us that had bushes that dropped tiny hair like needles.
Just make sure that as soon as it is put in the wheels are kept rotating to even it out. Anyone on a trade stand that offers this to a stationary vehicle is taking the wee.
Used to sell and insert a similar product. Caused many of my customers and therefore me a lot of problems. Nobody I know will repair punctures in tyres that have been treated. Plus as said by @laneside It must be applied very carefully and £30 is too much.
You don't get many bits stuck in your tyre - if you do, it seals anyway. This stuff, if it is like the stuff that I used to use, will seal small holes in tyres and the tread as soon as they happen. Larger holes might leak but at a slower rate. It allowed us to get off a motorway when we realised that our tyre had a slash and was deflating. I would put similar stuff in my tyres but the OKO stuff on Ebay isn't recommended for road use:
in the desert you get desert thorns that live just under the surface of the sand . get loads of them in the lighter van tyres . trucks arent so bad as stronger tyres . but gets used alot in tractors etc .
yes they say not for m,way sometimes not for road use .
bit like tyre sealant repairs with the rubber strips pushed in from outside they are only temporary . they are . fitted one in 2009, next year i will be changing the tyre . as its getting bald so yes they are only temporary.
if going through the desert or the tracks in africa always wise to carry them as well.
yes repairing later is not easy if oko is used . but have had the old fashioned heated vulcanizer repairs done in morocco even when i had used oko to get to the garage .
mind this was a side wall repair they did .
Reactions: f6c
I had an old trailer that I used to take stuff to the tip some years back. I might use it every couple of months and always had to inflate the tyres before use. Old tyres and rusty rims dont make a good seal. Put a bit of gunk in each tyre and gave a spin, all leakage stopped.
If you have considered tyre pressure monitors it’s a no no.
Never had any small holes in the tread or at the rim. Define a larger hole, the only one I’ve ever had was in the sidewall and big enough, when it went off like a shotgun, to put your fist in. Inner dually, never saw it coming. Slowly kept going to safety on the remaining wheel.
I got it from an independent local tyre fitter, tbh, I think it was a generic brand that was rebadged to suit individual retailers. Never had a problem that needed a tyre repair as I think it's good up to about 6mm diameter, but unless you're really unlucky, you won't often get that size of a hole in a tyre, even a 6mm diameter screw, once pulled out of the tyre, doesn't leave a 6mm hole.
The larger slash that we had was around 6 cm on the sidwall.
I use to get a puncture twice a year on my drive to work (along a windy country lane). After adding the goo, I didn't get any punctures.
Thank you all so much for your responses . It gives us an idea ,clearly this is the wrong time to buy ,as the van is in long grass and possibly stuck. Something to think about.
I knew that the forum would give us an overview.
I wouldn’t bother with it due to motorhome tyres being of a thicker construction, so far less likely to get a standard type puncture, and only suffer from more major punctures, which the additive won’t be able to deal with. It’s great stuff in wheel barrows, ride on mowers, and bike tyres, but not a motorhome for me.
