Depends on your personality, if you are worried about it you must get one just for peace of mind, however, chances are you won't want to change it yourself if it happens and, it happens so infrequently so what if you find some stroppy French man who insists you need To buy 2 it's not like it happens every day
Then if you have a run of bad luck you could end up with 2 spares and an empty wallet.If you had to buy 2 tyres from a stroppy Frenchman - at least you'd have the bonus of having a spare tyre, but obviously not on a rim.
We used it in our caravan tyres for several years with no problems, though when we put in a car around the same time it caused wheel imbalance, this was due to the tyres we had on the car having moulding ribs across the inside. We had it on another car with no imbalance problems at all. I don't think I'd use it now because if I have a damaged tyre I think it's safer to know about it and get it sorted, rather than drive about with an object stuck in there.sealant to put in tyre and is supposed to protect against 15mm dia punctures ! Anyone ever used anything like this, is it any good.
If payload is a problem if your already over you mite as well carry spare wheel,If payload is a problem, I'd wing it with neither and pray that I don't puncture.
For peace of mind get breakdown cover that will replace a tyre without needing a spare.
or if the only weight your over is a spare wheel then don,t worry about it ether.
Would not leve home without wheel and tyre.
Remember have a safe journey,
and a safe journey is being prepared.
Andy
No, well I hope not. The only problem is that you can be extremely vigilant and set the correct pressure, examine your tyres prior to setting off, and within ten yards pick up a puncture and know nothing about it until it's too late.Have pressure gauges become redundant
