Antony bleasdale
Looking to replace my tyres, Michelin agilis fitted at the moment but they have perished. A smooth quiet drive is more important than wearability
Many thanks
Many thanks
ay I ask what size you are replacing, and what weight the van ?Looking to replace my tyres, Michelin agilis fitted at the moment but they have perished. A smooth quiet drive is more important than wearability
Many thanks
C’mon spill the beans, what’s amazing between 15 and 16? Very interested as I’m on 15’s (contis) and want to move to 16”ay I ask what size you are replacing, and what weight the van ?
I have just this week been involved in extensive research , and the difference between 15" and 16" is quite amazing
One thing for sure, I will NEVER be putting Michelins on a van again !
Toyo H09 cracking tyres, winter spec too.
The worlds you Lobster !The size is 225/70R15
17800mls on van now, on contis 6mm fronts 10mm rears, plenty left in them running at 3.5 tons.My experience had continental tyres had to change them 19k put Michelin on still strong 40k no brainier for me
The research was not between tyre sizes Paddy.. But personal experience has shown there is not much to choose in noise, tyre wear and grip between 15 and 16" types... but there is a lot more choice with 15" tyres.. One surprise was how well 15" that are for big heavy 4 x 4's came out for motorhome use..Again Hankooks shone outHi Jaws -what difference have you found between 15 "and 16" tyres?
Paddy
I would like to know how you got them to grip ?I have run with both Michelin Agiles
I'm surprised to hear your comment. Both the conti campers and Michelin agiled were great road holding. Even in the wet. Useless in snow or loose gravel or grass but on tarmac brilliant. My MH was a Fiat ducato which ran always at max payload. Tyre pressure were 5 bar / 72psi in the front and 5.5 bar / 80 psi in the rear.I would like to know how you got them to grip ?
Not a mick taking question, as I would not rate them higher than say a 5 out of ten
Lost marks for traction in every situation apart from concrete based roads
( I am compare them with Davanti and Hankooks )
BTW, had the Davanti's put on the front this morning ..
Cannot give much of a report yet, but noise level was NOTICEABLY down on the old Avon/Cooper ones I had on for several months and the Contis I had on for 10 days
Every one has their own criteria Mike...I'm surprised to hear your comment. Both the conti campers and Michelin agiled were great road holding. Even in the wet. Useless in snow or loose gravel or grass but on tarmac brilliant. My MH was a Fiat ducato which ran always at max payload. Tyre pressure were 5 bar / 72psi in the front and 5.5 bar / 80 psi in the rear.
But while almost all tyres available in the uk ( apart from a few such as General Grabber etc which were never meant for European roads ) I have to take in to account all the times people with motorhomes are not on a paved surface... and have to be towed off pitches/show grounds etc If you have never been stuck in a soggy field you are just not trying LOL!!
As a matter of interest, when you say max payload what sort of weight / motorhome are you talking about ?
Having two of these tyres fitted tomorow to replace my Vanco tyres that are worn. Will see how they go seem to get good reports.We are Hankook agents and the reports we get back from customers and companies we look after who have had Hankook tyres fitted are very good I think they are one of the best tyres on the market at the moment just fitted some 225/75-16 RA18 with 120/121 load rating Hankooks for the second time to a company van the first set did 38k miles the company was very impressed with them and now fit Hankook to all their vans regardless of size
Just look around at HGV trucks when parked next to them at the lights you will be Suprised how many have Hankook tyres fitted
You will proly be shocked at the difference in noise levels..Having two of these tyres fitted tomorow to replace my Vanco tyres that are worn. Will see how they go seem to get good reports.
