Tyre Pressures, again!
Oct 7, 2013
6,369
41,301
South Wales
Swift Escape Compact
Since 1988
Some members may have seen, in another post, that I had replied to MMM’s article on the importance of maintaining the required tyre pressures according to axle loadings. I asked if they could comment on the fact that Peugeot and FIAT fit a TPMS that is set to 80psi. On my vehicle Continental’s recommenced settings are 59psi front and 64psi rear. Setting to these pressures triggers the TPMS giving warning messages and illuminating the dashboard warning light. Running 80psi, some 15 - 20psi over pressure gives a very harsh ride.
I had been trying to find a way to have the TPMS reset to reflect the correct pressures, without success.
I have now had a full reply from MMM which only compounds the issue, reproduced below.
it is long, and technical, but illustrates the stupidity of the lack of co-operation between base vehicle builders and motorhome converters.
Read it if you are affected and interested, otherwise feel free to move on to something more exciting.(y)
Please forgive the delay in getting back to you.
Upon receipt of your query, we have been looking into this, contacting manufacturers and asking questions in the after-market. The outcome of this is not encouraging.
We had a reply from Peugeot and they stated that they set the TPMS thresholds at the factory and these form part of the homologation process. These can be set to different levels at the factory if requested to do so by the converter and this change is covered by their homologation process. It seems that if the vehicle is converted in the UK, the settings can be changed by the dealers if they are supported by appropriate final homologation documents from the converter.
What did we learn from this?
That the dealers have the ability to do the change but they are prevented from doing so by Peugeot. If there is any hope of getting this done it would require the converter to instigate it. I think we have to conclude that this is not going to happen.
I have asked a couple of high street tyre businesses and have been told the same thing. They cannot change the thresholds and their diagnostic units have only the ability to 'clone' an existing tpms valve to a new one if needed.
I have looked at this from another point of view. We asked Fiat (as the majority player in the market) and they have not replied at all but using my diagnostic system (Multi-ECUScan) i have been able to deduce that the TPMS is controlled by the Body Computer, or CAN -bus system. There is an option to disable the TPMS and run what is called a 'Proxi-alignment' afterwards that will convince the ECU that TPMS is not present. This would prevent any under or over pressure warnings along with the TPMS warning light illuminating on start-up. Doing this would be contrary to the homologation of the vehicle and in theory render the vehicle not roadworthy. In reality though, the only people that would ever know this would be an MOT tester and since only cars and other passenger vehicles have TPMS as a mandatory fitment; they would not be looking for it anyway.
The Multi-ECUscan device only works on Fiat vehicles and Peugeot have a different main ECU, so i can't know for sure how this would work but the body computers are almost identical to the Fiat ones so any diagnostic that can access the CAN-bus on a Peugeot Boxer should be able to disable the TPMS just as easily. I have spoken to a local Peugeot specialist and he said that he uses Lexia3 which is the Peugeot specific equipment and is certain that he could do as i can with Fiats but he is unsure whether the vehicle would reset to factory defaults when re-started or if the battery is swapped. We definitely need a guines pig vehicle to try it out on!
Failing the above, there are only two other choices available. Live with the warning being on and have with you documentation from the tyre supplier to confirm the reasons for the warning light being on if you are challenged, or follow the advice that i found on YouTube today that showed the TPMS sensors being removed and placed in a sealed container, pressurised to the correct pressure and then being stowed in the vehicle to fool the computer into thinking all is present and correct!
In either of the above, an aftermarket TPMS system could be employed to make sure that you can show diligence and that you are monitoring the pressures indepenently of the on board systems. In the case of the former, you would just have to alter the tyre pressures before an MOT test to ensure that the light is off at that time.
I will be preparing a full and detailed item for the magazine shortly. I will be advising buyers to avoid the option of TPMS entirely while it is not mandatory. Or perhaps insisting that the converter gets the TPMS set at a more reasonable value during the homologation process.
It is surprising that the manufacturers have chosen to use this form of TPMS (known as DIRECT, where TPMS sensors are installed in the wheels) as opposed to INDIRECT which is based on the relative rotational speed of the tyres, employing the ABS sensors. Indirect systems can be reset to whatever pressure you desire. I understand that Ford and BMW emply Direct systems in some of their cars and that these have a resettable feature for the owner; so it seems that a mixture of the benefits of both systems is possible but such decisions are made before manufacture, and cannot be changed.
This is a throny subject and i hope that the above is helpful in some way.
Regards
Nick Fisher
Tech Help Editor
MMM
I had my “trigger pressures” lowered by a Peugeot garage. Some are willing/able to do it.
Yes, I remember you reporting that following my original post.
I have met point blank refusal from three Peugeot Professional garages and have not been able to find any independents who can do it.
We may need to organise a rally in NI!:giggle:
If Peugeot set it to 80psi then there must be a reason other than keeping the paperwork simple?
Peugeot generally fit Michelin who insist on 80psi.
Converters frequently then switch to Continental who give advice on axle loading v tyre pressures.
Check if you have Continental Tyres, check the tyre size and then visit tyresafe’s website. Input the details and see what you get. If you are happy to stick with 80psi make sure you have a good dentist in order to replace the fillings that may be shaken out.;)
Not motorhome but on my last car.
When I bought it there was a wheel sensor missing.
A second sensor disintegrated trying to remove the dust cap.
Solution...... Remove them all and a blob of bluetack in the responding warning light 'tube' on the back of the cluster.
Took a few weeks for the warning chime and warning message to admit defeat and stop chiming.
On checking the on screen warning it showed 0 psi in all four tyres.
The system works on a pressure differential between tyres...... No difference in pressures, no warning chime
Unfortunately not Peugeot’s system. The system you refer to checks the differential between wheel rotation speeds. If one tyre is lower than the others then it has a smaller diameter and faster rotation. If all tyres are at the same pressure, even if incorrect the system will not trigger.
The MMM response explains that.
I have a Fiat Ducato based vehicle and I purchased the Multicuscan software and adaptor. This allowed me to reduce my tyre warning theshold so I am able to run at more acceptable pressures - 60 front and 65 rear. The software runs on a windows laptop and cost £65.
My next motorhome, due in 5 weeks, is on a FIAT base so I will look into that. What year is your Ducati?
You may receive a PM asking for an explanation of the procedure if you done mind. (y)
On my Skoda I have variable recommended pressures for load of the suv & then I set the TPS setting to suit what I’ve inflated them to then it measures the difference. I’m pretty sure from 2022 all commercial vehicles like our MH base vehicles will have to have TPS in the EU so I expect they will also fitted to UK versions too
Fiat Ducato base vehicle……one set of pressures.
Sunlight the converters……… another set of pressures….different of course.
Continental Tyres……..yet another set of different pressures.
Tyresafe UK……..you’ve guessed it……different again.
I’m running on 65psi front and 72psi rear, a compromise of all the above. Should I be involved in a serious accident, who’s pressures would the investigators use? 🤷‍♂️
You are correct.
TPMS is now required for European homologation. Unfortunately, some are user adjustable and some not.
westfalia - was this a relatively straightforward process?
Yes. I seem to remember that the pressures were quoted in KPascals so, required bit of maths conversion to PSI.
I set mine to 4000 Kp which is about 58 psi. You set each wheel separately.
The software enables all sorts of tweaking so be VERY, VERY careful! :(
Handbook
A motorhome manufacturer can’t dictate the tyre pressures because the vehicle will have different tyres on it through it’s life.
Door pillar
The base vehicle manufacturer can’t either because they don’t know what is going to be built on it’s chassis.
Tyre maker
The only ones who can say what pressure should be used because they’ve extensively tested their products.
I wonder if it's tied in with the vehicle's emissions too, higher tyre pressures will return a higher mpg ?
By the way, if you want to adjust your own TPMS pressure thresholds on the Ducato or Boxer then in addition to the well known usual options (Diagbox, Multiecuscan, AlfaOBD) the standalone Autel MaxiTPMS TS508 will do the job. Not cheap at just over £200 but a simple to use solution that doesn't need laptop/tablet, adapters and cables etc.
I've just adjusted the reference pressures on my citroen relay using multiecuscan. I bought the package from Gendan.
Took a wee while to work out how to use the software, but happy to get there!
I took the van to a weighbridge and had continental email me their recommended pressures.
Before I pay out for multiecuscan.....
What year is your m/h?
I currently have Peugeot, shortly to be FIAT if the dealer can get its finger out. Yours is Citroën.
It shows it can be done, by owners, on some Marques, but FIAT and Peugeot?
Mine's a 2021 model. The software is actually for FIATs but most of the modules are the same.
Our TPMS dash light has been coming on intermittently. Usually followed by message TPMS not available. Only done 2k miles and had one sensor replaced back in May. Still keeps recurring. Took it to Fiat Professional today and they find both front tyres were 5bar rather than 5.5 bar and that raising pressures should solve the problem. Given the intermittent nature of the problem I am not totally convinced (and like others find such high pressures give a poor ride) but we will see. They have kept the vehicle over night and will road test again tomorrow.
2019 Base vehicle 2020 plate
Question: On the Fiat should there be an indication which tyre's pressure is wrong, ( my car shows all 4 tyres and there pressures on screen) or is it just a single warning light to check all 4? I suspect the latter but would like confirmation. Thanks
Drives you nuts, doesn't it? On my (2015) Ducato, it tells you which tyre it refers to. If more than one, it sequences them.
On the citroen (same module, so should be the same) each underinflated tyre is reported individually - along with the pressure it is reporting.
That seems very high pressures for the front tyres. 🤷‍♂️
I have heard cases of TPMS warnings coming up on vans which aren't being used often.
Yes I agree but that seems to be what Fiat specify. Several other threads on here have commented on reducing pressures but it compromises the TPMS as i understand.
Just to confirm that is a recent vehicle? which as you say has common parts with Fiat and comes out of same factory in Italy.
