Darren
My tyres are 225/65 R16 which is stated in the handbook. How do I find out the load rating I need ?
My rear axle Max is 2000Kgs and I was on tyres rated at 1030Kgs. each
Even to the detriment of fuel economy, (slight change of gear ratios) I went up a width to 225 so that I could have a bigger safety margin.
When coming off some of the 'sleeping Policemen' in France it was like dropping off the end of the World with a corresponding increase in load, especially on the rear tyres
I am considering doing the same. Do you know what rim width you have? Mine are only 16" 4.5J
Mine were 215 x 75 x 15. I 'upped' the width to 225 x 75 x 15. That's why the gearing changed (at the wheels because the depth of the tyre at 75% of the width increased the circumference slightly.
I've had a look at Oponeo and they don't have a rim @ 4.5J on a 16"
Flamenca changing the tyres to a higher rating may not be all you need to do. You may have to add air suspension to increase the axle loading.
You should give Sctech a call they will advise you.
I have air suspension on the back axle and that provides a rating of 2000 kg. I have already been through the 'uprating' process and have all the relevant documentation. Although my rear tyres are technically OK for the load I want more margin just like Emmit does.
How about this for info.
What have you got at the mo?Tyre to 5,50x16 Rim Fitment | Oponeo.co.uk
Make sure the tyre size fits your wheels 5,50x16. Use the "Fit the tyre to the rim Tool"!www.oponeo.co.uk
Are you sure about 4.5J? Our 2014 B544 is on 6J 15”.Mine are only 16" 4.5J
I made a mistake. Mine are 5.5J on 16". Apparently the 16" wheel version has a higher chassis rating and larger front brake disks.Are you sure about 4.5J? Our 2014 B544 is on 6J 15”.
