- Jun 20, 2022
- 1,672
- 3,540
- Just looking
Hello all.
Am currently planning swap from AGM to Lithium.
Apart from lights and phone/laptop charging our main current draw is the fridge/freezer at approx 52A in 24 hours. Maxxfan irregular usage.
Diesel hob pulls 4Ah and usage about 2 hours a day.
Diesel heater used in winter, but we only go for a few days at a time then.
Will be getting Fogstar (at least 300A), a B2B, an Inverter and a suitable Charger.
We have 300W of solar going through a Victron100/30 MPPT.
Will be powering a double socket outlet and initially using it for a travel kettle, hair dryer, portable induction hob and so on as and when necessary.
I'm confident that we will be OK with the above arrangements,
BUT, thinking about future proofing e.g. if the diesel hob knacked up and couldn't be repaired we would get a double slip in induction hob.
And of course extra Amps availability generates more need for other things.
For our initial needs a Victron 1200 watt inverter would be OK I think but with the above in mind am thinking a 2000W at least might be needed for future proofing.
A couple of questions,
Do any of you use an induction hob and how much does it typically take out of your batteries?
(Have looked at a hob from 12v planet, max output is 1800W which would be 150Amps, that's a lot to take from your battery even if you used it for just 1 hour).
Can I wire the socket outlet in the pic below directly from the inverter?
Anything else I need to know?
