TV aerial connections
Warks / Leics border
Low Profile Coachbuilt
Since 2012
I have just had an aerial fitted to my Hobby coach built. The fitter said when I picked it up that I just need to run a connection from the aerial terminal point ( the first photo) to the TV (the second photo). However the first terminal point is a threaded fitting and the terrestrial TV fitting seems to be the standard co-axial push in type. I might be thick but I can't find what I need.
Can anyone help with what I should be asking for. I can't get hold of the fitter. I looked in Wickes and saw something that might suit but it had 3 metre of cable.
Thanks. John.
The threaded fitting is called an F type connector.
(y) :cool:
So you need a lead with a male F connector to a UHF male connector, I believe.
