Truma 6002 EH on hook up
New Forest, United Kingdom
N+B Arto 74C
So the yellow light does not come on to indicate 230V EHU operation, but there is a good 230V supply.
Does that light come on regardless of the condition of the elements? or is it in series with the elements?
Do you mean there is a good 230v supply to the Motorhome , or to the Truma unit ,as there is normally an separate on/off switch in the Motorhome for the 230v supply to Truma heaters.
At the back of the heater on some models there is a reset button worth a try
If the 230v operation yellow light does not come on , but the green lamp on the control panel illuminates , it normally means that there is no 230v supply voltage or the overheat switch has activated ( as Bessy765 has suggested ) ) or the device fuse is defective , according to the Truma operating instructions
