13 years old will need to also wear a mask where YOU are required to wear one, and CAUTION if you're coming back after 30 of August the pass will be neede for all teenagers from 12 to 17Hi All. My husband and myself are fully vaccinated do we still need antigen tests when traveling to France ? We are traveling with 13 year old, obviously not vaccinated. We are totally confused. HELP !!!
Look at the 'France may soon go green' thread , plenty of info on there including how to load your vac certificate onto the French app (all in English)Hi All. My husband and myself are fully vaccinated do we still need antigen tests when traveling to France ? We are traveling with 13 year old, obviously not vaccinated. We are totally confused. HELP !!!
Which pass are you referring to?13 years old will need to also wear a mask where YOU are required to wear one, and CAUTION if you're coming back after 30 of August the pass will be neede for all teenagers from 12 to 17
That's correct (currently) if you have had both jabs. Confirmed here.Now I am totally confused. So we don't need a test to go just coming back. if double jabbed
The equivalent of French Pass (double jabbed papers , not QR code as different from the French one, or negative test you have to check if it's now less than 48 hours or 24hours. According to the dates it might be different)Which pass are you referring to?
You've confused me now, why would you need the French pass to come back to the UK?The equivalent of French Pass (double jabbed papers , not QR code as different from the French one, or negative test you have to check if it's now less than 48 hours or 24hours. According to the dates it might be different)
Iwona1967 said "when traveling to France ?" and I said caution if it is after the 30th of August the 13y old one will need to be fully jabbed as it will be the rule here at that date. Never said it was to go back to UK . Just being here in FranceYou've confused me now, why would you need the French pass to come back to the UK?
Ah I read 'coming back' as coming back TO the UK.CAUTION if you're coming back after 30 of August the pass will be neede for all teenagers from 12 to 17
I really think you should just go - you re posting on anything and everything with France and Spain in the title so you obviously want to - Just Man up/woman up ( other choices are apparently available) and go for itI'm so glad we've cancelled.
Couldn't agree more.Once your here you soon realise it’s worth a bit of paperwork. Soooo chilled out and so much room. Just pootaling along with nothing booked, waiting to see what we find.
Bliss.
Yes that requirement came in last Sunday (18th). It's a French rule but is listed on UK government travel website. The rules are changing (on both sides) almost dailyJust spoke to him, he and his wife who are double jabbed are fine and did not require anything more but the over 12's needed a negative test and they didn't have a test so no boarding, just organised a lateral flow in Kent tomoz and all being well they will be on their way Sat afternoon
