Touchpad problem on Mac (3 Viewers)
2,335
10,112
The touchpad on my Mac G4 Powerbook has an odd problem, it only works on the left hand side.. about 25% of the total area .. the button is ok and an external mouse works ok ..
I've searched the Mac sites and tried the following:
* Cleaned the surface
* Done a hardware check . all OK
* Opened up and checked inside for a loose ribbon connection or dust
* Reset the PRM as per Apple instructions
* As a last resort, reformatted and installed a fresh OS X
All to no avail :Sad: Any suggestions ??
Nov 12, 2010
149
83
Northamptonshire
Hi Top
5 Years
A bit "off the wall" but have a look at this page; Link Removed , this guy reports that he had a similar problem caused by a deformed battery. Try to avoid any suggestions about changing the case top panel, just had to have it done on my Macbook Pro and it cost a mere €400 to have it done.
Good Luck
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
Sounds like a hardware problem Jim, despite your check reporting it as OK. Have you been to Sys Prefs and switched off any gestures and the option to ignore accidental trackpad input? It occurred to me that a hardware fault might have affected the pad's sensitivity on the right-hand side.
Other than that, I'm at a loss. I guess it is quite an aged trackpad, so may have reached the end of serviceable life? A trip to the Apple store service desk may be the only option.
Philip
2,335
10,112
Trade up to a PC ::bigsmile:
Bea me to it Jim ::bigsmile:
Thanks guys, I knew I could depend on the PC brigade for sympathy :Sad:
Good Luck
Thank, read that post yesterday .. my battery is old but ok ..
Philip
Thanks Philip , I was coming to the same conclusion .. but not giving up on fixing , will have another look at the gubbins today, nothing to lose ..
To be honest, if it needs a new top case then I think I'll sell it for spares or repair, the screen also needs renewing ( has a broad white band on the left and two other pixel width vertical lines, so we are looking at the thick end of £600 for parts , which doesn't make economic sense on a six year old Mac ... :cry:
EDIT
Concluded that touch pad is faulty .
Second hand top case £105 (includes touchpad)
Screen: Grabe B £150 New £210
so, £260 to buy parts .. or save up for a new Powerbook ..
I'll ask Santa ,... I think he is still taking orders..
Pikey Pete
1,481
1,143
o
o
Well you won't get a 'new' Powerbook but a MacBook Pro. would be a good idea:thumb:
Pete:Cool:
2,335
10,112
Pete:Cool:
yes indeed.. forgot they had changed the name ..
at the mo' I'm using an even older G4 Ibook so not in a great rush ..
dazzer
1,620
102
In my house
Virtual RV!!
10 Years
Its an Apple machine....get your money out and get it fixed (at 10 times the cost that any other lappy would cost to be fixed!!)
2,335
10,112
Not biting mate, :roflmto:
if I get the parts (hopefully second hand) I'll do it myself .. and it will still be 10 times better than any new windoze lappy. :RollEyes:
Oct 1, 2007
7,064
13,964
Kirby cross further from londin
Between Motor homes
since 08
would an ordinary tailed keyboard and mouse work using usb temporary
ive only just become a mac user
so i am probably daft
just ignore me for making stupid suggestions
2,335
10,112
not stupid at all, yes that would work..
however, my keyboard is fine , and I'm using a Bluetooth mouse .. :Smile:
Bear in mind, this Mac has had six years of hard use, including three while full time in a motorhome where it had it's fair share of rattling around the dashboard when being used as a Sat Nav .. so it aint done so bad :winky:
Oct 1, 2007
7,064
13,964
Between Motor homes
since 08
would one these help £59;00
if the attachement works
nope didnt work
Oct 1, 2007
7,064
13,964
Between Motor homes
since 08
what is it ?
sorry havent got to grips with macing moment right clicking in m/soft used to r/click
on web addresses and then paste not so with apple
but do a search for apple magic trackpad
they are listed on apple its wireless
its an aluminium plate resting on a tube containing the battery size approx 5" x 5":thumb:
looks better than i describe
it works like an oversized pad on a lappy but no buttons just pressure left or right
when missmanagement insistead i bought one (ground her down)
1st fella said i could swop mouse to trackpad
3rd fella lost the will to live two hours later and threw it in for free
2,335
10,112
they are listed on apple its wireless about
ahh yes, I know what you are showing me now .. as supplied with the iMacs, not sure if it works with the older PPC macs.. probably not ..
My Bluetooth mouse is pretty good , but it's odd not having the trackpad working.
Oct 1, 2007
7,064
13,964
Between Motor homes
since 08
at work we use a keyboard in the van cab, with a trackpad to all intents and purposes its a lappy keyboard on a wire/usb
lappy in a safe in the rear
i use one on my dell lappy
(fixed in position higher than needed)
extra keyboard sat on a pull out tray
ill get a pick of the keyboard tommorrow
Oct 1, 2007
7,064
13,964
Between Motor homes
since 08
pics jim keyboard in the van
