- Oct 29, 2021
- 1
- 0
- Nexxo 660
Hello all,
I recently purchased a Burstner Nexxo 2011. The toilet compartment seems to have a leak which I am looking into by replacing seals, possibly buying a new cassette.
I have noticed a couple of things in the actual toilet compartment which are strange. I have attached photos.
One of the compartments beneath the toilet cassette has a black tube in which goes through to underneath the van. You can see straight through to the ground.
Secondly someone appears to have drilled a hole through the bottom left corner of the toilet compartment as if to allow any leak to drain away. I'm not sure where this hole goes.
My concern is where this drain goes and whether these holes are likely to be bad in the long run.
I am based in North Lincolnshire so if anyone has any suggestions about affordable places if an inspection/ work may be required I'd be grateful for recommendations.
Thank you
Stacey
Thank you
Stacey
