- Dec 3, 2019
- 7
- 3
- John McBain
- T-line 590 newbie
Hello and welcome. More expertise will be along shortly but let us know what controller you already have for electrics. Modern ones often have a setting for AGM/GEL/Lead-acid. They will charge but have slightly different peak charging levels and you don't want to boil them or conversely undercharge them regularly.Hi folks, just joined last week so this is my first post. I'm replacing my AGM battery on my Tline 590 and replacing it with two Yuasa 100AH L36-EFB batteries. Can anyone tell me if the charger will charge these batteries ok given that they are not AGM batteries?
AGM batteries have a much higher voltage during the absorption stage and lasts much longer before moving on to the float charge stage. .
Depends on the type of AGM type 1 the bulk charge should be 14.7-14.8v, type 2, 14.2-14.4v.Agm will charge in the region of 14,4v to minimise electrolyte
Who's the manufacturer of the ec176, it sounds like a Sargent unit but I can't find it on their site.Thanks guy but not being electrically minded I'm still unclear about swapping out single AGM for twin Yuasa' s. The charging is done through an ec176 power supply unit I think if that's any help.
It is indeed a Sargent... fitted to Autotrails to name but oneWho's the manufacturer of the ec176, it sounds like a Sargent unit but I can't find it on their site.
If it is Sargent that would be a control panel, what is the charger?
Hi Wee McB,
Sorry I can't answer your question as still finding my way around my T590, although you can be sure someone on here will provide the info/expertise. I wanted to ask where you propose fitting the second battery as I'm looking to do the same later on?. Regards the battery charger - my 2018 model Nordelettronica NE 21A. Incidentally this is our first motorhome and 10 mths on it has been fantastic in all aspects.
Nigel.
So perfect for wrecking any battery connected to it.Found this:
"The charger built in the EC176 is a fixed voltage charger capable of delivering : DC Output 13.8 Volts nominal, Current 12 Amps max "
My Sargent is exactly the same.. never reaches a full charge state, but I have never worried overly as we rarely use it.. the solar regulator does a proper job.. But if we used hook ups a lot I would have changed the charger out years agoThe OP needs to fit a decent multi-stage charger before changing the battery as any battery will be ruined in a couple of years or less & will never get fully charged probably no more than 70%.
