Thetford fridge - not working! (1 Viewer)
Sep 27, 2017
66
31
Hymer 630mlt
Since September 2017
Hi -
Help! My fridge is not working! Had it working on 240 volts at home on drive! Travelled to Grantown on Spey from near Edinburgh and found fridge led was flashing! When I checked Hymer manual found that this could be lack of energy source so changed it gas whack I knew was fully charged! Seemed to accept change of energy to gas but started flashing again! I’ve changed the batteries in the compartment- 6 AA batteries- and again thought that I had fixed it but after a few minutes reverted to flashing again! Now the freezer is dirge and freezer is not working and I think I’m going to have to go home to try and fix problem! Any ideas gratefully accepted!
faraway
744
607
Kent
Chausson Flash 10
Getting better
Does it have an outside cover and if so, has the cover been removed?
3,774
10,540
1995-2004 & 2017》
Hi -
Model no.. would help.. think must be quite an old model if still has AA batterys. Sorry can't help but sure someone may be along soon
However unless for medical reasons can you not manage without fridge for a while and still njoy yer holiday??
2dandaddy
Sep 27, 2017
66
31
Hymer 630mlt
Could manage without fridge but would loose contents in fridge but would still have to fix problem!
3,774
10,540
1995-2004 & 2017》
Yes I understand that.. yes of coarse it needs fixing. But it is surprisingly how long stuff in fridge will survive ( you said it worked on drive before leaving).
You may have to bin some, but replace as required and enjoy you holiday..
Granton on Spey is a lovely place with opertunitys to restock... Coop being one..
2dandaddy
Sep 27, 2017
66
31
Hymer 630mlt
Poppycamper- thanks for that! You’re right just a bit inconvenient really! Just panicking a bit! Could stay another couple of days and sort problem later!👍
3,774
10,540
1995-2004 & 2017》
Had a look on tinternet... without more info cannot be positive... however it says some thetford fridges come with a battery backup ( AA battery's) which are only there to back up your normal 12v supply..
Could your 12v supy have failed and you have been running on battery backup..
Yes I know you said you changed battery's but might be worth checking your 12v supply.. assuming you have one..
Any way njoy your ice free Gin and Tonic Holiday..
2dandaddy
Sep 27, 2017
66
31
Hymer 630mlt
😂! Certainly going to try! Thanks for the input!👍
1,436
29,230
Nelson New Zealand
Autotrail Tracker FB
Since 1998
I am going to suggest you check the obvious.
1. Are you parked on level ground.
2. When was the last time you cleaned the gas jet?
Our Thetford fridge/freezer flashes an LED with a spanner symbol and a number to indicate what the problem is. I'm assuming yours doesn't do that?
3,798
8,173
Milton Keynes, UK
Burstner Lyseo 727G
Is it a auto selection fridge? If in Auto mode it should choose between 12V - starter or possible Leisure battery, Gas or 240. If the engine is not running it should run Gas (if open/switched on) 240 (if plugged in to EHU) and 12 volt ONLY when engine is running. You can select manually if you choose to. No AA batteries in mine. If there are that would only run the 12V operating system not the actual fridge cooling system. It would be dead in 1 minute if you did that!
My N4000 series Thetford fridge operates like this (2020 ish).
Again - model would help. Should be in a sticky piece of paper somewhere inside the fridge. Inside door or on the inside wall.
RedFrame
1,330
3,804
Chester
Self Build W907 PVC
Sept 2017
As has been stated fridge model, somewhere inside the fridge compartment would help, however, at 2017 it's a good guess that it's an aes absorption unit.
Try a few things, with the fridge in auto selection mode, to try to narrow down the issue.
1) Run your engine, does the fridge switch to 12v, does the light stop flashing.
2) Stop the engine (ignition off), after 10-15 min does it switch to gas, do you hear the ignitor clicking, after the clicking do you hear the faint roar of the flame (listen at the outside vent).
3) Book a night at a site with ehu, plug it in, does it switch to 240v and stop flashing?
One other thought, you have turned your gas to the fridge on haven't you?
Cheers
Red.
2dandaddy
Sep 27, 2017
66
31
Hymer 630mlt
Cheers
Red.
Thanks for all the replies!
Tried switching on the engine and fridge/ freezer worked! Switched engine off and within 20 minutes started flashing again! Weather has turned for the worse so going home on Friday and will hook up to mains to check operation! Do you have to remove fridge unit to get to connectors! One other thing which is puzzling! Battery pack 6 AA batteries does not appear to have any electrical connections AND has no springs to keep all batteries touching each other?!?! How does that work?
10,150
18,455
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
Sounds like a leisure battery fault if it works with alternator input,could just be a bad connection that the increased voltageovercomes but I would check leisure batteries first
2dandaddy
Sep 27, 2017
66
31
Hymer 630mlt
Model no. N- 3142. Absorption
22
33
Hymer MLT630
7 years full timing
The 6 batteries compartment is to power the control panel only, it doesn't do anything else.
You need to remove the outside vent, clear any cobwebs and dust, debris. Get a torch and thoroughly check all the wires and connectors you can get to. Check the voltage of your leisure batteries, and check all hab fuses if any have blown. Start at the basics before going in depth. I could write a thesis on fridge woes from my previous van 🙃
434
429
Cathargo
Sounds like the gas is not getting through (crash sensor/bottle valve/valve inside van), or there is air in the pipe that needs a few starts to dissipate. Most only run on 12v when the engine is running, not when stopped, which yours seems to be doing, then after 15mins on 12v it should switch to gas if available, and motorhome level enough (Sometimes mine doesnt ignite, and I switch the power off leave 2 mins and switch back on, then it works). EHU should trump the other two if available, and fridge on Auto.
RedFrame
1,330
3,804
Chester
Self Build W907 PVC
Sept 2017
So, we have the following information:-
1) The Fridge works on 12v (this mode is used only when you are driving).
2) We believe, with a reasonable degree of confidence, that it works on 240v (it worked in this mode immediately before you left)
3) You get an error on Gas.
1) Check the gas isolation valve for the fridge, make sure it is in the same position as your gas stove isolation valve, and that your gas stove works.
2) You need to "listen" at the lower outside fridge vent after switching the engine on then off, after a max of 15 min you should hear the rapid clicking of an electrical ignitor.
2b) Immediately after the clicking you should hear a gentle "roar"of the gas flame at the lower outside fridge vent.
Cheers
Red.
suavecarve
7,761
39,748
Surrey/Hants
Rollerteam 685
July 09
What was it using as a power source when it worked for 20 minutes after you turned the engine off ?
Presumably not 240 and shouldn't be 12 volt so must be gas ?
RedFrame
1,330
3,804
Chester
Self Build W907 PVC
Sept 2017
An aes fridge doe not run on anything for 15 min after switching the engine off, unless it is then provided with 240v via EHU.
It's a safety feature to try to prevent the gas ignition operating in. fuel stations (it also doesn't error during this period)
Cheers
Red.
2,558
33,640
essex
2017 sunlight t69s euro6
When it starts flashing what code is showing on the extreme results of the panel after 15 mins ,I have the same fridge and repair it often as mine does not like 12v ,you have a gas problem ..turn the fridge off leave it a few mins turn it back on select gas manually if it does not light it will show a fault code on the rhs of the panel
3,798
8,173
Milton Keynes, UK
Burstner Lyseo 727G
My thoughts to. Sounds like a problem with the gas. Is the bottle switched on? Any other isolation valves not switched on?
By the way -you don't HAVE to wait the 15 mins for gas to kick in. It's a safety feature for when you drive into a petrol station to fill up but if, after you have switched the engine off, you switch the fridge off and then on again it will immediately go to gas.
1,465
1,643
North Ayrshire
Adria Matrix 670SC
Can you establish what the actual problem is by selecting each power source manually and find out what it's not working on. You will need the engine running to try it on 12v. As others said the battery pack is only for operating the controls if you have a 12v hab battery failure. It's only a temporary measure.
295
477
Hartland, Bideford, Devon, UK
Ixeo 1744
I’m newbie
1) Turn fridge power off
2) Try turning all gas knobs off at there terminals
3) then turn gas terminal on only to fridge
4) then after a few seconds turn fridge back on .
This is to force any air out of gas line to fridge.
This worked for me .
Good luck
2dandaddy
Sep 27, 2017
66
31
Hymer 630mlt
When you have done the above, check the error codes...
You have to go into service mode, and it gives you an error code.
If the link doesn't work, search for thetford n3000 troubleshooting, on the thetford europe result download the pdf file 👍
Good luck
Hi Eyeballmike - just read your input- really helpful! Will try putting in to service mode and see what happens! Really appreciated, thank you👍
2dandaddy
Sep 27, 2017
66
31
Hymer 630mlt
Cheers
Red.
Hi Redframe - thanks for the input! Fridge works when engine running and on 240v hook up! Code 11 comes up on fridge panel when on service mode! Can you tell me where any fuses/relays would be for fridge /freezer?
2dandaddy
Sep 27, 2017
66
31
Hymer 630mlt
Your welcome, also your profile says we have the same model mh 🙃
Hi - sorry to bother you again! Fridge works on 240v and when engine is running! I can hear and see igniter working but doesn’t fire up!Put the panel in to service mode and got code 11 up! Think that is no energy source which I presume is 12v supply! No idea where fuse/ relay is situated for fridge! Any ideas?🤞
