THETFORD DUPLEX OVEN & GRILL
Peterborough, Cambridgeshire
Carthago Chic E Line
Since March 2004
Can anyone tell me if the above oven is any good ? This is the "built in" version without the hob.
Thinking about fitting one but need to know whether or not it would be worth the investment. I.E. are you able to cook ok with the oven, roasts etc. Does the grill work ok?
Many thanks
Fitted the SMEV one which works okay, did fit a fan behind it though to get rid of the heat.
Sat in the van at Jim’s so just taken a picture but it’s a bit dark.
We can confirm that the Duplex oven works well, we have one and and it cooks everything we put in, grill works well too. We have electric oven at home so just had to get used to a gas oven. And there is even a pull out heat guard to protect the adjustment knobs from the heat when using the grill because you have to leave the oven door open whilst using the grill.
I specifically asked for a Thetford in my new van because they are the most powerful I could find. It's for better than any Dometic ones I've tried. Recommended
I had trouble finding a grill pan that would fit on slider's
