Thetford cassette (1 Viewer)
bubble
185
69
Suffolk
Auto sleeper
Returning after break
hi, we have just got a new to us 1997 Hymer B544 and the electric flush on the toilet is not working , is there a fuse for it please, or is there anything we can check, it has water getting to it and we have found the relay, when you push the flush you can hear the micro switch clicking. But no flush, help please. Thanks in advance.
Badknee
7,280
389,210
notloB
Vantage Neo
Living the dream.
Has the toilet got it’s own tank or does the water come from the main fresh water tank?
bubble
bubble
185
69
Suffolk
Auto sleeper
It comes from the main fresh water tank.
bubble
bubble
185
69
Suffolk
Auto sleeper
Hi, still hoping for for advice please, anybody have any ideas, thanks.
9,072
17,622
Newcastle under Lyme
Hymer B544 A Class
Since 2015
On my 2003 b544 I think there is a fuse for flush on the wiring in the cassette locker.
Does bathroom lighting work, I assume it would be on same circuit as the flush.
Could be a fault on the micro switch ?
138go
3,276
14,612
Carthago 138
Since 2001
Is the 12V circuit in the MH switched on. Is the water pump circuit switched on.
Fletton
1,531
4,242
Lincolnshire, UK
Knaus Sky I Plus 650LG
First MoHo - April 2015
If you can hear the relay clicking.... when you press button
And your water is pumped via main tank...
I would be listening for pump ... and if pump operates... I’d consider an air-lock first...
If pump none operational... issue with something tween relay and pump.. or pump turned off -
water at all other taps?
22,543
121,024
Lorca,Murcia,Spain
Transit PVC
6 years since restarting
It would appear to be a lack of power to the pump from the switch, assuming there is power at the switch. As others have said start with finding the fuse & if that is ok trace the power to the switch & back to the pump.
3,667
3,086
Low profile
Water in main tank?
Water at taps?
Dump valve (frost protection) closed?
11,702
13,620
Eastbourne East Sussex
Hymer low profile
Since 1972
There is a fuse, reachable from underneath after removing the cassette
However if the valve is clicking the fuse is probably ok. It doesn't have its own pump so the water pump has to be on.
2,425
8,445
Cumbria
Burstner Solano t725
since 2014
Don't know if this will help...
This, the manual tells me, is the fuse for flushing the toilet on our Burstner 2010
It is in the outside locker that houses the toilet cassette.
Barry
bubble
bubble
185
69
Suffolk
Auto sleeper
Hi, thanks for your messages, we have water in the taps shower and at the toilet, pump for main tank working fine, can’t find a fuse anywhere, light in bathroom works great, 12 volt on . Still not working.
9,945
17,623
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
there is a solenoid valve in the toilet these can stick might be worth getting it out and cleaning check theres power to it when flush button is pushed theres also a micro switch connection if your pump is microswitched rather than pressure operated
bubble
bubble
185
69
Suffolk
Auto sleeper
Thank you will try that today.
bubble
bubble
185
69
Suffolk
Auto sleeper
Ok found the fuse and change it and flush was trying to work but could smell burning so took the pump off attached to inlet water from tank and it’s burning hot so think it’s that part that needs replacing, the filter in it is blocked , no surprise van has been stood for a long time before we got it so off to the boatyard near us as they might have a Thetford part on the shelf. Will let you know if it fixes the problem.
Puddleduck
12,214
42,688
Scottish Borders
SunLiving Lido M45SP
On and off for many years.
Glad you have got the problem identified. Hope the part arrives when due and sorts the problem.
bubble
bubble
185
69
Suffolk
Auto sleeper
Thanks so much, gradually sorting out how stuff works, a few minor bits needed sorting but we expect that it’s an old Motorhome 1997. But we love it and we hope it will take us on great adventures.
4,819
26,590
Uk
C class
Since 2017
Great that you’ve found the cause of the problem,and have a solution.
Also great that you’ve let folk know you’ve progressed............. many don’t bother,which is just rude. Good luck with your adventures!
David 51
Hymer Camp 2.8jtd
View attachment 282627 Hi, it was the cassette water valve at fault just ordered a new one. Not held on Thetford stockiest have to order it, arriving on Tuesday. Thanks again.
We have the same problem. Where did you find the water valve located near the cassette toilet? We have the same locker access and piping you showed. I take it the valve was in the bathroom in near the toilet?
