Thetford C200 Holding Tank aka Cassette. (1 Viewer)
Apr 7, 2008
64
110
Garstang, Lancashire, UK.
AutoTrail Tracker RB
Since 1968.
Well not a good way to start the day but here goes.
My holding tank on the C200 Thetford dump station has decided that it really wants to stay put. I tried and tried and tried without much success to remove it gently to no avail. Anyroadup, I gave it a coat of looking at, cursed and cursed and eventually got the thing out. Happy days.
Went to the emptying point and all went well. Now this is what really got me thinking there's something not quite right. Like we do, some rinse the thing out by running water into the spout. Others, like myself, pull the slide thingy back and open the blade and off we go splashing water all over. My slider had to be assisted with a screwdriver to slide it to the open position.
With me?
I then close the blade and slide the slider back into it's position with matching arrows side by side.
Back to the motorhome thinking all is well but no, I just couldn't get the cassette into it's place all due I think to the slider thingy not wanting to slide back as it does when replacing the cassette under the bowl.
Am I missing something?
HELP.
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
On mine, the slider moves easily, so this could possibly be your problem. Also, are you sure the blade is fully closed when you took the cassette out? I had a problem removing the cassette a few weeks ago, I had to open then close the blade then it was ok.
You could try leaving the cover off and trying to slide the cassette back in. If it goes in easily, you may have your answer.
DavidMarsh
Apr 7, 2008
64
110
Since 1968.
Ah, tried checking the blade action and making sure it was closed. When the cassette is out of the motorhome, after a fight, even then thats when I need to lift the front lip of the slider. I've just spent the last forty five minutes messing about with it. Must be the newness wearing off!!!
DavidMarsh
Apr 7, 2008
64
110
Since 1968.
Hi Stephen.
Nah, it must be the cleanest holding tank ever! Even after the usual Coca Cola treatment of the inside of the tank the outer surfaces and anything attached is now gleaming with WD40. No Grit and no other stuff either.
May 7, 2016
7,257
11,745
West Sussex
Carthago Compactline
Since 2003
The blade opening device on the cassette has to line up with the blade lever in the housing. If either bit has got out of position or jammed the cassette will not come out or go back properly.
gozomike
Funster Life Member
1,001
863
Warwickshire - sometimes - but not often
Wildax Constellation
Since August 2008
If WD40 has been on the seals it has probably not done them any good (understatement), they could have expanded. As JJ says Silicon is the thing to use.
Khizzie
3,794
5,695
Le Repaire,Thiviers,France
Autocriuse stargazer
since 2002
Just a thought ,was the actual toilet slider fully closed before trying to remove cassette? If it wasn't I suspect there lies the problem and damage has resulted by forcing the cassette out ..
Riverbankannie
10,535
61,558
Bristol
IH 630 RL PVC
I have a loose fitting plastic panel about 4 x 6 inches that needs to be sitting correctly on the floor of the compartment before I slide in the cassette. Sometimes this does get out of place and prevents me sliding the cassette back in place. Mine is a SOG toilet and I dont know if it anything to do with the SOG.
I have never had to force the slider on the top of the cassette open, that sounds odd.
DavidMarsh
Apr 7, 2008
64
110
Since 1968.
I do use silicon on the seal, the WD40 was used to clean in general.
Dec 12, 2010
5,413
21,573
Cumbria
since 2011
Have you tried removing the sliding flap and then trying to push the cassette in, the flap's not needed for the toilet to function.
DavidMarsh
Apr 7, 2008
64
110
Since 1968.
Oh yes. It's a bit late in the day so I'm thinking I'll take the whole thing out tomorrow, strip it down and see what happens.
