Temp sensor (1 Viewer)
Lanerboy
1,363
2,206
midlands
Carthago 4.9 superior
Does anyone know where the temperature sensor the fiat one that tells the outside temp on the dash is on a 2018 built carthago, mine seems to be reading high by about 6-7 degrees so was going to change it can't be bothered with claiming under warrenty too much hastle so was going to change it myself
I know some vehicles have them in the wing mirrors
Forgot to say it's an A class
43,331
49,467
It may not be faulty, I would expect it to either work or not work.
Chances are its the new position the converter has placed it in.... To close to the radiator or engine or maybe even because the engine bay is more enclosed.
Don't know where its usual factory position is but a favourite is behind the grill in front of the radiator where its out of the airflow.
53,448
150,064
Standard Ducato's it's in the LHS door mirror, but an A Class I would go with you, somewhere up front behind the front skirt.
Lanerboy
Lanerboy
1,363
2,206
midlands
This may be correct as if I remember I think it reads faulty whilst driving I need to check tomorrow to see what it reads whilst sat on my drive
andynkim
107
200
Mobilvetta K-Yacht 85
I had a similar problem on my 2019 mobilvetta, the o/s temp sensor was over reading by quite a lot and rose over running time. I found it under the floor between the chassis rail and side skirt on the offside just behind the drivers seat. The converter had used there own thermistor and after checking it there was corrosion around the thermistor.
Luckily I had the original fiat temp sensor supplied loose in the glove box swapped out and it is now perfect.
Cheers Andy
andynkim
107
200
Temp sensor is in the offside mirror on standard Ducato’s the aerials are in the near side.
Feb 21, 2016
4,920
29,552
Uk
Since 2017
Mine’s just outside the drivers window..........I stick me arm out,wave it about,and say to the duchess Cor, its everso ‘ot out there. Hahahahaha.
andynkim
107
200
In case its required here are snips from the 2016 converters manual. Faulty temp sensor will affect the climate control and the comformatic gearbox.
Lanerboy
Lanerboy
1,363
2,206
midlands
Just been and checked the temp reading and it's correct whilst parked up 11 degrees I did wonder if it was ok when stood so this means it must be getting heat from the engine to increase the reading ??? So is the sensor in the engine bay as mentioned above
53,448
150,064
Mine reads accurate when driving and stationary but will read high for 20min after stopping which is what makes me think it's up the front. On an A Class the converter could fit it anywhere.
I expect someone in the Carthago owners club will know.
Feb 22, 2016
3,613
10,732
York
Bailey 620 Approach
Not quite the same but in our Peugeuot based Bailey, the temperature would read correct when stationary, but when driving, would increase until it reached the maximum then start again from the bottom. Cured itself when we had a new cab battery fitted. Temp sensor now behaves as normal. So maybe try disconnecting cab battery for 30 mins and see if this sorts it.
Lanerboy
Lanerboy
1,363
2,206
midlands
Had an email back from the carthago dealer they said it could be some where around the inside of the o/s/f wheel arch so need to have a look if it stops raining
