Tap pipes connector
Bursner Nexxo 660
Does anyone know how to disconnect this tap from the two water pipes?
I need to get the tap out in order to re-assemble it after replacing the microswitch and there is no play in the pipes.
Thanks for any help
Graham
Where they go into the tap there is a locating pin. Push this out then pipes can be removed
see those two big brown plastic covers remove them and they will expose the srews that hold that box to the walls, remove screws, remove box and you may see the connectors
I have pulled the new wires in by soldering them to one of the old wires, then no need to remove pipes etc. Yes its a bit of a fiddle!
The pin to remove the pipes is shown on this poor internet photo.
but I would do as above to remove box and expose two, probably push connections, that are nice and easy to undo.
