Relay Re-Lay
- Feb 21, 2024
- 4
- 2
- Citroen Relay L3H2
Hi (cherry popping post)
Tankless LPG water heaters.
I'm looking at getting one with the idea to mount it in a vented lockbox on the outside of my rear barn door. The LPG would be mounted on the inside of the same rear door. Enough pipe play will be given for the opening and closing of the door.
All looks well in principle and on paper but here's where I need some help.
Can the system be set up so I can just turn the hot water tap on in the van without having to keep going to the outside rear of the van to turn things on. In other words can it just be left on for instant use.
Hope that makes sense and look forward to seeing your replies.
AJ
AJ
