Swift kontiki heater element
stubbskonti22
swift kontiki
Hi, this is for my dads swift kontiki, he has been told his hot water heater element is faulty, unfortunately they don’t make this style anymore and will need a new tank and heater £1000 plus fitting🤔 surely this part must exist either at a breakers or maybe reconditioned. The element on this tank is supposed to be like a band that wraps round the tank rather than pushes into the tank. Could any of you experienced folks help me out. The van is I think 2004 ish
You will need to tell us the make and model of the water heater, a photo would help as well.
:welco:
I assume it is a Truma C6002E Combi, you can still get the heater collars for them they are about £400. But it could just be a faulty thermal cut out those are about 6 quid.
Probably not worth fitting a new collar just run on gas, every van we have had the Combi boiler has been gas only.
Hi, yes it is a c6002eh truma trumatic combo boiler, where would I source a heater collar? Rarer than hens teeth I assume. Is there a new boiler that is a direct replacement?
Replacement would be a Truma Combi 6E if you want to retain the electrical element of the system, it will be considerably more expensive than your previous quote and not a straightforward drop in replacement.
If it’s the same as my Truma c3402 which has a rubber belt element, mine stopped working.
I watched YouTube video on fixing the thermal fuse but my thermal fuse was ok, mine was a faulty thermal cutout switch. Replaced that and all’s good. Cost around £6 but most of that was postage cost.
This is element-red arrow
