While checking the MoHo it appears the control panel display has failed in our Swift Kontiki, Is there some way it can it be re-booted or is it fubared....
have you tried removing it and disconnecting it, leave it for a minute then reconnect again? it used to work with our swift bolero whenever it refused to boot up
So I tentatively removed the panel and found this in the back, so hoping replacing will solve the issue, seems mad something wired would also have a battery also....
I have put the battery back in and its not the battery, tried the re-boot process as above, nothing seems to happen. Display screen illuminates though not displaying any info/ menu on the screen
I currently have MoHo on EHU on drive and have just found out we had a power cut in early hours Sat morn, just turned main panel on/off and display is now back on...
If your Swift control panel is unable to stay alive without a 240 volt connection then it's worth checking that your leisure battery is in good order. Not sure of the age of your motorhome but three years from new the batteries fitted as standard tend to fail.
I have exactly the same panel and it sometimes freezes and wont turn anything on.
I just cycle the power button on the sargeant unit and it resets no problem.
