steel wheels
Martha2
Hymer 544
since 2009
I am struggling to find new 14inch, 5 x 118 studs, steel wheels for our 1993 Hymer 544, any ideas. I could get the originals refurbed
but would prefer new., Thanks
You need the codes off the original wheels and this will give the rim width and offset etc, what is the original chassis?
Having them grit blasted and coated they would look like new , unless they have hit the kerb that many times the rims are dented.
A nice set of good quality wheel trims will cheer you up no end, that’s what I did with my 1993 Pilote
It is on a 1993 Fiat Ducato LHD
go to your usual tyre place and get them to check the offset and rim width. probably 6.5j width though
looking online they are not easily available, although the 15 inch 5x118 as used on the mk1 ducato are
Broken Link Removed came up with the goods for my weird steel wheels. I don't know if they've got what you need. You need to find your PCD, hole number, diameter, width and offset.
