Status 530
Ode
Peugeot compass ca
Struggling to get any TV reception to Ariel socket on other side of van
And........? A little more detail perhaps......?
:unsure:
If you have a good signal when going directly to the amplifier then it can only be a cable issue between that and the socket. Check the back of the socket and the connection to the amplifier. And make sure the amplifier is turned on :)
if one socket works but the other not, I would suspect a wire is unplugged or broken, or the plugs badly fitted with the core touching the outer braid
Thanks for replays I will check the items out as suggested
I fixed a van with a similar fault the other week for a friend. Everything looked like it was connected fine but no signal. The coaxial wire run behind the cupboards was super skinny, so easy to damage. I ran a new wire with new F plugs down the van. One end to the amplifier in the wardrobe and the other to the tv via an F plug converter. Tuned the tv and got 100 plus channels. Before it was getting none
TheBig1 checked and found the same issue putting new cable in tomorrow
Job done perfect picture also wired a couple of USB double sockets and switches in while doing this job thanks for advice from other members
