I don't buy cheap gear off Ebay, I tend to buy from 12v Planet. I have queried this issue with 12v Planet and await their reply but wondered what others on here do.
Take this busbar as an example https://www.12voltplanet.co.uk/4-point-positive-distribution-block-busbar.html
It uses stainless steel washers which as we know have a high resistance and therefore fitting a cable to the busbar should be crimp terminal on first, stainless steel washer next, then spring washer and finally the nut.
But the washer is too big in diameter so does not sit well on crimped terminal, it sits at an angle, and even torqued up there's still an angle - see photo.
What do others do?
What do others do?
