can anyone help please....
Just returned from a week away, first of the season, filled up tanks and bled the water system..
However I cannot stop the taps from spluttering. When you first turn them on, they splutter, and then run normally. Then when you turn on the tap again it splutters. This happens on both hot and cold water....
The pump turns itself off as it should, once the tap has been turned off. The pump is a sureflo.
Thanks in advance
Thanks in advance
