- Apr 13, 2019
- 1,946
- 48,358
- Ci Coachbuilt
- Since September 2018
Here’s one for the sparky peeps.
Might seem daft but here goes.
Currently have one 100 amph leisure battery of lead acid type under passenger seat and no room to fit a second.
Do have room for a second lead acid battery in a portable battery box however,in the front passenger footwell for use when not travelling ie on site.
Distance from battery terminals on box to fitted battery is no more than 2 to 3 feet.
Would it be permissible to connect the 2nd leisure battery to the fitted one in situ and then use the extended 12v power to last me longer than just 1 battery.
Also , could this set up be used if EHU was available to charge both 12v batteries?
Finally, would a 100w portable solar panel be a good idea connected to either the battery box battery only, or directly to the in situ battery only, or to both, running from the solar panel connected to the 2nd battery which in turn is connected to the in situ battery, ie in tandem.
Can’t / don’t want to Put solar on the roof, switch to lithium and reconfigure the charging circuits as the age of the set up and subsequent resale would be uneconomical, and I’m not made of money!
Thanks for any advice.
