Spare 15 inch (3 Viewers)
vicwo
62
40
South Yorkshire
Rapido 866f
since 1998
I have a as new 15 inch steel wheel with my present Rapido. New van has arrived at dealers with 16 inch alloys. Would a 15 inch make the new van limp in a puncture situation ?
If a Funster would like to swap for a 15 inch please get in touch.
I will be round South Yorkshire and Southampton in June.
I'm in Tain l Hermitage on the Rhone at the moment and a Rapido 9000 DFH brand new expensive thing on the next pitch has a spare wheel fitted. Got me thinking.
Oh and its hissing it down here. Cheers all
Flamenca
1,266
804
Europe
Hymer 564
The differential on the transmission would probably be very unhappy with different size wheels fitted on the drive 'axle'.
Mr B
990
1,889
Yorkshire
Rapido 7065ff Design Edit
Since 2015.......
I think you'll find they are different PCD holes so no good anyway. :(
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
Probably will not fit anyway, the diff will not like it either for any distance.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
If it's a brand new van it will probably fit as they've started using 118 pcd on both sizes but I would not advise it.
vicwo
vicwo
62
40
South Yorkshire
Rapido 866f
since 1998
Thanks all it will end up on e bay if nobody needs one
Techno
Jul 28, 2010
15,475
20,756
May 2010
Make sure you get the correct spec from you supplying dealer but this is the new 16" wheel with 118 rather than the older 130 pcd
THIS is the older version
vicwo
vicwo
62
40
South Yorkshire
Rapido 866f
since 1998
Hey up Techno yes thanks that's the one I was looking at. I bet the weather is better back home in Yorkshire than over here in France. Thanks again
Techno
Jul 28, 2010
15,475
20,756
May 2010
Mixed today but crackint flags tomorra
Mr B
990
1,889
Yorkshire
Since 2015.......
I thought 15in after 2007 were 115pcd?
Techno
Jul 28, 2010
15,475
20,756
May 2010
Not on Sevel wheels. In fact they've been 118 since at least 1998
here is a spare
Wheel Features
Brand: Kromprinz
PCD: 5 X 118
Size: 6J X 15
Load Rating: 1000kgs per wheel
Offset: 68
Fittment Issues: Will not fit Maxi
Suitable for: Fiat Ducato 2006-2016
11,955
16,570
A more immediate problem than the effect on the diff. is likely to be the effect on ABS under braking and the effect on stability control - both of which work on the assumption that both wheels on an axle rotate at the same speed. At best it would light the ABS fault light; at worst it would cause instability during heavy braking.
