- Apr 10, 2021
- 23
- 25
- Autotrail Apache 634
Hi All - We’ve had our 2014 Autotrail Apache for almost a year and got away for 3 weeks last year to Sweden in-between lockdowns. We were without electric hook up sometimes for 2 or 3 nights at a time. But we did drive around during the day and have solar panels. As time went by the leisure batteries performance deteriorated so I am looking at replacing the leisure batteries.
We’re not sure if the set up with the solar system and batteries is correct as we assume an additional leisure battery was added and perhaps an additional solar panel. I have attached a drawing of the solar panel connection to the batteries via a Sunsaver 20L controller.
I believe the Banner Energy Bull 100Ah is the original Autotrail supplied battery and, the Duracell Advanced Extended Life Performance 100Ah DA100/UK 019 was added later. I also noted the Duracell battery is not actually listed as a leisure battery!
The motorhome has an EC500 power control system and EC300 control panel over the habitation entrance door. The EC300 Solar Current to Leisure normally reads 0.0 to 0.1A. The Fox D1 battery display does give the battery voltage and current, in this weather, perhaps 0.5A to 1.5A current.
On the following links you can access a photo/plan of the solar battery wiring and also a photo of the solar panels.
If possible, can you please advise on the following:
- Is the wiring of the system, correct?
- There is no connection to the Sun Saver controller load – is that normal? I assume the connection is elsewhere as the 12v habitation system works.
- Are the batteries connected properly to gain the best benefit from them?
- I assume some will know the likely rating of the solar panels from the photo, can you please advise on what they are?
- Can you please advise if the solar panels are suitable for charging two 100Ah batteries for the UK April to October. Just LED lights, water pump, charging mobiles, ipad.
