solar panel fixing to the roof (1 Viewer)
tonka
10,833
21,531
Cannock, Staffs
A class Burstner 800
Since 2000
Yep Sikaflex.. I have used 221 or 521..
Make / buy some brackets, fix them to the panel to allow airflow and cooling underneath.
Just stick em down, job done...
Jaws
23,836
72,487
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
I tend to use the above, but if there are any rails up there I usually attach one end to them.. Makes for a real quick, absolutely solid installation
Scout
3,959
121,302
South Yorkshire
chic c line
12 years motorhoming, a lifetime of living
What about fixing to a manufacturer s roof rack.
Oct 1, 2013
7,512
19,937
Lanzarote
Nil by mouth
Lots
So do you just stick the whole thing to the roof?
I assumed there were feet or summat.
And what happens if you need to take it off? E.G. For repair.
911
661
Cotswolds
Bailey Approach 625
Since 2011
Sikaflex is the way to go, however they have a bewildering array of seemingly identical products.
I identified the material of the MoHo roof (painted GRP in my case) and the material of the mounting brackets (ABS plastic).
Sent this information to technical@uk.sika.com, received a reply within the day with the recommended product, Sikaflex 252 in my case.
Mar 26, 2009
8,163
11,221
Yr Wyddgrug
Hymer B678DL
Since 2009
For none flexible panels you don't stick the panel to the roof. You stick the mounting brackets to the roof with the riveted or bolted panel attached to the brackets.
(It made sense to me when I typed it:unsure:)
1,700
3,988
mid-Norfolk
since 2006
My Rapido has a "floating" roof fabric so I would need to drill and screw into the solid roof material: simply gluing to the material may result in a panel blowing off and taking the fabric with it!
If in doubt, do it with care - Gordon
mentaliss
654
306
Lancing
C class
I've been using Tec 7 for the last three years, customising camper vans etc the caravan industry have been using Sikaflex for years and years and in fairness nothing much else was around but once they lost the paten rights to their M7 Polymer Adhesives many new types of this adhesive have come along...the point of the story you don't have to pay Sikaflex prices anymore:):)
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
My roof is the same but with no screws and they dont come off
I have never used screws on any panels I've fitted and no reports of panels on the road behind yet.
7099F of my friends
Broken Link Removed
Broken Link Removed
Techno
Jul 28, 2010
15,475
20,756
May 2010
Do you mean the brackets on my van first pictures?
ES Cumbrian
321
143
Cumbria
Autotrail
3 years
Just done mine using these, cut the cable in half that gives you + and - plugs on the roof to plug into the panel then the cut ends go through the gland fitting into the MH ot run to the controler.
Broken Link Removed
Broken Link Removed
Broken Link Removed
