I have fitted a panel to the roof of my Hymer and it has the same controller as the vehicle charger system, it just clipped on and plugged in. However as the panel is 120 watt I could do with a bit more so I would contemplate fitting another further along the roof but the controller is limited to the wattage it can control. to 140 watts maximum.
Question is can I fit another panel and another controller and use them to feed the same battery bank (3X90amphour) by just fitting the output from the second controller straight to a fused connection and the batteries, Is a diode needed or would the battery bank voltage act on both controllers equally, allowing them to limit the total inputs from the related panel???
