Minxy
- Aug 22, 2007
- 32,656
- 66,564
- Carthago Compactline
- Since 1996, had Elddis/Swift/Rapido/Rimor/Chausson MHs. Autocruise/Globecar PVCs/Compactline i-138
I made a start on my solar install yesterday ... shouldn't have bothered ... took me ages to find some of the stuff that hubby had 'tidied up' (ie hidden and forgotten where!) then my tools wouldn't play ball ... a slipping chuck on my mains drill meant the bit kept jamming in the hole I was drilling and stopped dead with the chuck still spinning. Getting the cable down through the hole was a feat in itself and fed down to the top of the B pillar - I tried to remove a decor panel on the side of the overcab locker/shelf, having to carefully slot my head in without taking my ears off, all to no avail as it wouldn't budge once the screws were out ... then the crappy cable ties I had kept breaking not to mention other stuff that decided it wasn't gonna give in easy either!
The ONLY thing that worked well was getting the cable down the B pillar as I found I didn't need to use my plumb bob method (ie drop it down the inside and tie the cables to the string and pull them down) ... all in all what should have taken a couple of hours max in total took waaaaaaayyyyyy too long although I did get the regulator installed along with a feed to the cab battery and a cab battery charge display but not the solar panels themselves this was by choice though as the camper was due to go into Fiat today for some warranty stuff so I didn't fit the actual panels themselves as I was concerned the adhesive wouldn't have sufficient time to set so that'll be the final job when it comes back home hopefully by the end of the week ... I'm missing fettling it already!
