- Oct 8, 2014
- 1,831
- 3,685
- Autotrail Excel 600B
- Previous VW Camper + Caravan
At last I have finished the installation of a 100W Solar Panel on my MH. I used the tried and tested method of Aluminium Angle riveted to the panels and then bonded to the roof using Sika 512.
All that is left to do is to fit some trunking between the panels and the gland through the roof.
Instead of a more common MPPT Solar Controller, I have fitted a CTEK D250S Dual. This acts as a MPPT controller, and 5-stage B2B charger, and also charges the Vehicle battery from solar, once the 2 x 110Ah habitation batteries are fully charged. I have fused the output from the CTEK, and fitted an isolator for the input from the Solar Panels.
The CTEK unit can handle 340W Solar, and charges @ 20 Amps from the Alternator. Although this is not as much as a Sterling B2B, it should meet my needs, at a much lower cost. I have already noticed that following a journey, the Habitation batteries are charged better than they used to be.
By using the combined unit, I know there will be no conflict between B2B and Solar Charging.
