Solar controller not acknowledging my new solar panels (2 Viewers)
RubytheT5Tardis
4
4
VW T5 high roof
HELP !!! Can't get my solar controller to work. I recently installed 2 x 100 W flexible solar panels, The front front panel on the curved roof being a nightmare to stick down. neatly 🫣 I won that battle after an epic solo struggle. I was then kicked in the teeth by a solar controller that refuses to acknowledge the solar panel 😭 thankfully the panels are working, providing sufficient voltage and current, confirmed by multimeter & connecting the solar panel directly to a 12 volt socket and a low power appliance working beautifully.
I tried the connection sequence procedure several times... Battery then solar.
Still no joy 🙄
Ordered another solar controller and changed. Still no Joy 😭😭😭
RubytheT5Tardis
RubytheT5Tardis
4
4
VW T5 high roof
Still no joy 🙄
43,512
51,029
What's the voltage on the center 2 wires (output) wires or the controller?
If that's it in the first pic 12.7 then that's battery voltage and not solar.
Disconnect the 2 while wires and test again
RubytheT5Tardis
RubytheT5Tardis
4
4
VW T5 high roof
Centre two wires, to the battery, showing 12.3v on my meter with load disconnected
Polarity correct As in red should be positive.
But anyhow you put me on the right track and then I investigated further back.... And Eurica !!!! My extension cable from 2 panel joiner is connected the only way it physically fitted in, but I discovered black input goes to solid red output to controller. It can only connect that way at the joiners. You couldn't make this shit up !!!
😤 So now I have done the previously unthinkable connecting my red wire to the minus on the controller.... And Thunderbirds are go 🥳👍👍😍😍😍😍
Take a Bow Pappa John 👍🤩
RubytheT5Tardis
RubytheT5Tardis
4
4
VW T5 high roof
Update. gone from 77% battery last night to 100% by 8am after sunny morning.
So very impressed with the performance of these cheap light panels !
Apr 27, 2016
7,010
8,216
Manchester
A class Hymer
Since the 80s
I notice that you are using the 'Load' terminals of the solar controller. Normally the load terminals are not used in a motorhome/campervan setup. Usually the solar controller is just connected between the panels and the battery, and all the loads are taken from the battery directly. The load terminals are usually fairly low power, not enough to power anything except very small devices.
Load terminals are used in other applications, such as garden lights, road signs, CCTV cameras etc, and usually have a function to switch them on/off at dawn/dusk.
