SOG Kit (3 Viewers)
herbies
123
24
somewhere in south devon
hymer b694
I apologise if this question has been asked ad nausea but Im thinking of putting in a SOG kit thought i would check out the current thinking on this.
It seems a lot of money for a plastic hose and a vent
thanks:Doh:
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
But a beautifully engineered tube and motor and load of other bits.
Excellent buy.
126
109
North Suffolk
Panel van conversion
since 2011
thanks:Doh:
If it seems a lot of money for a plastic hose and a fan, wait until you save a fortune on chemicals and special toilet paper!!
I fitted this system a couple of years ago and I cannot imagine having to use special chemicals etc., it is just so easy to use. Apart from changing the charcoal filter every year there is no maintenance whatsoever.
If you find the stench unbearable when you empty the cassette, :ROFLMAO:
just pour a small amount of bio washing liquid into the toilet just before emptying and this kills any odour.
Mel
2,131
2,810
De Haan Belgium
Caravan LMC
Since 2010 Caravan since 1995
Yes I think its expensive.
But for me well worth it.
But you can build your own if you are handy.
Terry
11,932
9,085
Lincolnshire
Can't remember ;)
Broken Link Removed
1 x 3 1/2 ins comp fan used instead of the 2 smaller fans :thumb: cost zero :thumb:still working after 6 yrs :thumb:::bigsmile:
terry
johnp10
7,774
15,181
North Lincolnshire
8 years ish
I have seen Brian Hilldweller's SOG and it looks a well engineered bit of
Serious question:
Help me out here. have I got this right?
A SOG unit will expell the odorous gases whilst the loo is in use. (Look for an outlet before you park near one?)
In emptying the cassette, some form of deodoriser is still required to kill the smell of the contents, so less, rather than no chemical / whatever is used?
Is that the deal?
The principle sounds great but the practice doesnt sound much different except for no smells in the van, the benefit of these being given to whoever is parked downwind.
Potentially a bit antisocial?
Is it overall a beneficial bit of kit, or just another toy?
Good topic for Sunday lunchtime, eh?
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Why ?
It's a grim job at best. It lasts a few seconds. I can take that.
We use no chemicals at all.
And the kit:
External moulding, filter.
Inside a quality little fan unit.
A cable harness with microswitch on a bracket.
A pipe. Beautifully made with quality plastic.
An adaptor to replace the normal cassette vent.
A blank cap to replace the tube whilst dumping.
Goo instructions.
German quality.
It is not a rip off.
steveclecy
880
580
Wirral
Since June 2009
Or buy the liquid from here - £1.60 for two weeks supply (emptied daily) with ordinary toilet tissue.
Steve
Terry
11,932
9,085
Lincolnshire
Can't remember ;)
Serious question:
Is that the deal?
As Brian has already said no chemicals needed -- Just to make things clearer when you open the sluce it turns the fan (via micro switch)on sucking in air from the bowl bit so you should get no smells entering the loo ::bigsmile:When you had done your jobby etc, you close the sluce and this in turn turns the fan off :thumb: job done ::bigsmile:IF you are getting smells from the outside bit then the charcoal filter needs changing :Smile:
If you think the casstte smells bad that is when some posh folk stick in some bio liquid :Smile: but basicaly you empty the casstte every day or two just as normal and if that gets up your nose there is not much you can do about it :ROFLMAO:::bigsmile:
terry
edit forgot to say we only use Charmin loo rolls :ROFLMAO: SOFT ON MY BOTTY ::bigsmile:
johnp10
7,774
15,181
North Lincolnshire
8 years ish
All is explianed.
Didnt realise there were filters etc.
Sounds like a good bit of kit even if only to keep smells from the van.
Thanks folks.
Terry
11,932
9,085
Lincolnshire
Can't remember ;)
All is explianed.
Thanks folks.
Did you see my DIY SOG link ? very easy to make one :thumb: and even if you had to buy all components it would only cost around 25 quid ish - very easy DIY :thumb:::bigsmile:
terry
Bath overflow x 2 £4
micro switch £3
light switch/blank £2
Comp 3 1/2 fan £5
wire /silicon/sup glue £5
charcoal filter
johnp10
7,774
15,181
North Lincolnshire
8 years ish
Use of deoderising liquid or not, I'm beginning to think this is a good bit of kit, even if only to get an odour free "function".:thumb:
oldun
747
162
St Neots
VW Campervan
Since 2001
terry
It seems like you spend more on toilet paper than I do on chemicals!!!!
eddie
8,157
41,271
Taunton Somerset
RV
since 1989
If you like the whole camp site to know when you use the toilet: Go for it lol
Basically every time you flush air is brought from the inside of the van, into the "potty" bit across what is ever in there and straight outside.
So if your loo is on your caravan door side, every time you "flush" you "waft" :winky:
Oh and in hot weather, it makes it a joy to empty as it stinks to high heaven. If the answer to this is to put some chemical into the "potty" bit why bother with pipes and bits of plastic in the first place?
The tank is only open for the time it takes to "flush" so any smells inside the motorhome are more likely to be bottom emanating than tank smells.
I hate them personally too fiddly and seem superfluous in the extreme. There was a big argument on here recently about how social/anti social grey water was, what about a poo smell wafting around your BBQ every time your neighbour empties their bladder or bowels :winky:
Just an opinion
Eddie
Terry
11,932
9,085
Lincolnshire
Can't remember ;)
Charmin £7.50 for 24 :thumb: a lot cheaper and better than the proper loo rolls for chemical loos at nearly £2 for four :Eeek:::bigsmile:
terry
Peter @ JCM no smells emitted just hear the fan purring away in use :thumb:They all smell on empting -but don't panic I am teaching my 7 yr old g/son how to empty the loo :ROFLMAO:::bigsmile:
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Eddie
So that's a no vote from Eddie.
But what about inside, better the smell briefly, if at all, wafting past your neighbours than stuck inside the van peeling the veneer off the walls.
Ours is on the back wall but I guess you have a good point if the toilet is next to the hab door or main window.
The fan does not have to go in the hatch, depending on build you could route it round a corner or even on to the roof using a chimney type outlet.
The cassette is normally equipped with an open vent for pressure equalisation, it can vent next to the cassette or in our Burstner it had a half inch flexy tube routed underneath.
872
3,359
Leyland Lancs
since 2001
Just an opinion
Eddie
Some of the smells from BBQ's are worse than those expelled from SOG's.:ROFLMAO:
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
Just make sure it doesn't blow out into your awning. Chemicals are not expensive, a bottle of tesco bio will last a month for £1.50 or less. Use ordinary loo paper, it breaks down just as well and you'd need to use it anyway. The filter on a SOG does need changing regularly and costs £10 a throw, whether it lasts a year is up to your nose :ROFLMAO:
