R
Yes it canThis is a serous question - honest! Can this system tilt the vehicle so waste tanks can be completely emptied?* You can do this with full air suspension but I'm not sure these jacking systems could cope with the lateral forces. But I am probably wrong.
*Like a dog cocking it's leg.
Another benefit is knowing that you're going to be firm - all night longI will refrain from asking about other cures for excessive wind...
Hi.Another benefit is knowing that you're going to be firm - all night long
Hydraulic levellers are usually mounted under the van.I like the neat way the hydraulics are underslung and out of the way. That's an advantage on smaller vans as in the video. All the examples I've seen on here it's mounted inside and takes up storage space within the van,
Correct ish, our pump is also inside but we have the room so it's not a problem, if there really is no room inside or the customer simply doesn't want the pump unit inside Mick at SAP will mount it outside in a custom made plastic box.Hydraulic levellers are usually mounted under the van.
Only the hydraulic pump is inside and is about the size of a large shoe box
In a perfect van yes ... But we all have motorhomesThinking about draining water, shouldn't the drainage be designed to work when the van is level, rather than tipped in any other direction?
Not sure what the extra weight is but we were able to remove the two Alko steadies from the rear and do away with the chunky quatro levelling ramps we carried. That must have saved a fair bit.Is it much extra weight added to van other than a spirit level
You're right of course, it should. But how many do?Thinking about draining water, shouldn't the drainage be designed to work when the van is level, rather than tipped in any other direction?
Other slightly cheaper options are also available
http://www.glide-rite.com/category_s/12.htm
Btw we also have the full air and it is better at emptying the tanks because its faster. Press the button when you leave the cab and by the time you re at the tap its tipped to an impressive angle.
I have had glide-rite fitted to two vans and they work fine so why tell us to steer clear of them? Have you had any bad experience ence of them on your van?I'd steer very clear of GlideRite. They're not much cheaper but significantly inferior (IMV) to E&P and the other offerings I've seen.
That's about the price difference I had in my mind from when I was looking, I don't think that GlideRite have the bells and whistles of the competition but I have never heard of a problem with them.Ive had gliderite on for 5 years, absolutely fine and were £1500 cheaper and a bit lighter at the time.
