I had an issue with a Snipe Pro Max failing to park. The solution was to completely disconnect the power supply to the control unit (the circular unit that you have in the habitation area) and then, after a short wait, reconnect.
If that doesn't work, Avtex's first step on units under warranty would appear to be to send out a replacement control unit. Is yours a Snipe Pro or a Snipe Pro Max?
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
